Opinions on RTA-11T vs. SDA 2b?
John in MA
John in MA Posts: 1,010
edited December 2006 in Vintage Speakers
Just curious about how you folks think these speakers would compare. Highs, lows, clarity, power handling, etc. They seem similar in driver design, with the 2b having a large single PR instead of two, and of course the SDA feature.
Post edited by John in MA on
    F1nut Posts: 52,000
    2B's, hands down.
  • John in MA
    That big a difference with nearly the same drivers?
  • george daniel
    george daniel Posts: 12,096
    F1nut wrote:
    2B's, hands down.
    ^^^ Yep ^^^
  • riglehart
    riglehart Posts: 276
    I've owned both, but never at the same time. So, never did a side by side compare. My two cents is, if you are going to sit down in front of them and do quality listening, the SDA's are always better. If you are going to put them in a room full of people and party, the 11Ts take up less space and will pump out the same "noise", actually maybe a little more because one set of drivers isn't used for SDA.
    Jolida Tube
    Polk 11T, 7, 5, 5jr, 4
    Standard equip not worth bragging about.
