Opinions on RTA-11T vs. SDA 2b?
John in MA
Just curious about how you folks think these speakers would compare. Highs, lows, clarity, power handling, etc. They seem similar in driver design, with the 2b having a large single PR instead of two, and of course the SDA feature.
Post edited by John in MA on
2B's, hands down.Political Correctness'.........defined
President of Club Polk -
That big a difference with nearly the same drivers?
I've owned both, but never at the same time. So, never did a side by side compare. My two cents is, if you are going to sit down in front of them and do quality listening, the SDA's are always better. If you are going to put them in a room full of people and party, the 11Ts take up less space and will pump out the same "noise", actually maybe a little more because one set of drivers isn't used for SDA.Jolida Tube
Polk 11T, 7, 5, 5jr, 4
Standard equip not worth bragging about.
