Some pool pics...
steveinaz
steveinaz Posts: 19,546
edited December 2006 in The Clubhouse
So far, as of yesterday:
Post edited by steveinaz on
  • audiobliss
    audiobliss Posts: 12,518
    Wow. So that's what a pool looks like before it's a pool, huh? When's the projected date of completion?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • steveinaz
    Probably around late March, early April. It works out well as the plaster needs to cure for about 30 days before adding the salt.
  • steveinaz
    Dual paper element filter. The SWCG cell is just behind the pump, you can barely see the top of the cartridge.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Built-in pool cleaner? I'm asking due to all to bottom drain pipes.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • steveinaz
    Yes, in-floor pop-ups.
  • szhleppy
    szhleppy Posts: 325
    Coming along well Steve! I don't know about you, but I was impressed with the rebar job the kid did for my pool. Completed the entire thing in about 8 hours by himself and everything looked perfect.
    Wow...couldn't have timed that any better for pool season!
  • steveinaz
    They still have alot of rebar to go, but I think it will be done today. Timing did work out well.
  • disneyjoe7
    Steve,
    Look at your pool now... As things get done the pool will look smaller and smaller... Until there's water in it then the size will increase a little. I watched 2 pools being built and found it funny just thinking about that fact.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • steveinaz
    I was thinking how small it looked when they first spray painted the layout---Bev panicked in fact. Now it's looking a little bigger.
  • disneyjoe7
    Wait until shell goes in... Then it looks small. When the deck goes on it will look larger... Then when the diamond bright goes in it will look small again. It's all a little funny when all said and done.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • mrmusicman
    mrmusicman Posts: 303
    looks like a money pit.
    Outlaw 990 Processor
    Outlaw 755 Amp
    Denon 2900 dvd-sacd
    Dishnetwork HD-Dvr
    55" Sony LCD RPTV
    Lsi 9-fronts
    Lsic-center
    Rt55i- surrounds
    Velodyne cht-10 sub
    2007 Dodge Quad cab
    Kenwood Excelon KDC-X891
    JL Audio 300/V2
    Polk Audio SR 6500 - Fronts
    Polk Audio DB651 - Rear
    2 -10" Treo Subs
    Interfire IB 2600C sub amp
    Sirius Sat radio
    Ipod connection
  • disneyjoe7
    Steve,
    Now is the time to think about any future upgrades you have in mind. Like solar heat / heat pump how would this be added in the future? The pool direction does it face north, wheres the electric feed to the pump equipment is the south? If pump equipment is no the south side no big deal on adding solar because these pipes will go up wall to roof. But if your pump equipment is north because the electric is north (I find pool people don't like to put pump equipment different then AC feeds) you may consider adding pipes for solar now under deck because this would be a cleaner look later. And fewer holes in roof to worry about if piping didn't run from one side to the other on the roof. Same is true about electric needs for the future if adding heat pump, should you add another pipe for a second AC feed now? Cement is so permanent.
    I myself have 2 sources of heat for pool (don't like pool unless it's 84-88f) thinking about adding a third Heat pump as the solar it's doing much now in the winter. So now I'm rethinking about the electric AC pool sub-panel now 30amp feed. The electric for HP would need a 50amp so should I have the sub-panel rewired for 80 or 100amp then have to 50amp breaker all together with other pool breakers? Or have to 50amp from the main panel like the 30amp is now?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • steveinaz
    Per the builder, the in-floor cleaning system allows us an easy way to integrate heat later---but I seriously doubt we'll heat the pool. Arizona is very hot and the summer is long. Solar covers work almost too well here, some friends of mine actually leave the cover off often because the water gets too warm to be refreshing.
  • Strong Bad
    Strong Bad Posts: 4,278
    We need to know only 1 thing...
    When is the First Annual Polk Fest Pool Party?
    "Let's see how well these SDA's float (SPLASH)...hmm, not well. Ok, next round of drinks bartender."
    :D
    No excuses!
  • disneyjoe7
    Steve, I know Arizona pool will be hot but when a pool is over 90f it sucks. You need to lower the temp so you have these options. A large ICE block in the pool, Solar panels working at night to cool off the pool, or a Heatpump for cooling off the pool. So you may need to have electric pipe or water pipe under the deck, think about. Talk too some people and get their input for these options, now is the time. You will save some $ later or you will like the way it looks.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • PolkWannabie
    PolkWannabie Posts: 2,763
    In the southwest I believe ( correct me if I'm wrong ) the temperature at night usually gets significantly cooler then it is during the day i.e. to the point where it drops a fair amount below the temperature that pool water potentially climbs to. If that's the case then a simple floating device that sprays pool water into the air like a fountain will suffice to cool water temperature with little to no original or operating cost.
  • disneyjoe7
    Ok, guys I just trying to look forward options. I sold my old house and one reason was I can't get the pool install people to add a spa. They said no I asked 4 times no, I could use another company but I would kill my life warranty for my shell. So if it had a shell leak later I'm on my own. I don't wait to hear you later that you should did this or that.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Libertyc
    Libertyc Posts: 915
    WOW - that is a very big high-dollar job. Looks like it will be very nice. Let us know when the Polk pool fest is.
    BTW - did you install underwater speakers??
  • PolkWannabie
    DJ,
    IMHO Spas are better done as separate installs where they don't share equipment ...
  • disneyjoe7
    I'm sorry and wish too take this back, it has been a bad day for me and I'm not in a great mode. Hindsight is always 20/20 and life can be 10000000000/20 or so.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • steveinaz
    It's cool brotha, I appreciate the heads-up and info. I'm new at this, but also have busted the bank already on this build...$33k
  • disneyjoe7
    33k mine was 42k :D Looks really nice even impresses pool people.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • SamK
    SamK Posts: 13
    Do you make pools? I should be inviting you over to build one for me :)
  • Strong Bad wrote: »
    :D
    I would think a properly sealed SDA would float very well. It would depend how it landed when it hit the pool. We might have to find one to investigate further.
    When is the party?
    Isn't this like 11 years old ? Steve doesn't even have that house anymore.
  • Willow
    Willow Posts: 11,246
    edited February 2017
    Yes, he and Bev moved and from what I remember there is no pool at the new place. Heck even DJ7 doesn't post anymore...
  • tonyb wrote: »
    I didn't think to look at the date. Got suckered right in.
    Who else has a pool? We have a totally non scientific float test to conduct
    I've had pools before, from above ground to in-ground.....pain in the butt. If I were to do it again, salt water is the way to go. My area though requires too much to maintain a pool, opening and closing, heating....which can get very expensive because even in summer in my area the ground temp stays roughly at 58 degrees which means your always running the heat. My neighbor has an inground, gas heated, spends 700 a month in gas to keep the pool at 80 degrees. He can afford that though, the average joe would rather have a Mercedes in his drive way than a pool he can only use 3 months out of the year in my neck of the woods.
    EndersShadow Posts: 17,719
    Did Steve get banned?
