amp queston
goingganzo
well it is upgrade time and i would like some advice
i want to upgrade my amp in my theater and would like some advice. should i go 4 2 channel amps or 1 7 channel amp?
i am looking for at least 200wpc 8 ohms and around 4k used for 4 two channel amps or new for 7 channel maybe used
my speakers are a custom buld with dual 6.5 in with xbl^2 and the vifa ring tweater like found in lsi but top of the line dome meteral.
Post edited by goingganzo on
Four 2 channel amps would definitely be more impressive to look at, sonics may be better depending on the amps and if one goes down you're not totally SOL.Political Correctness'.........defined
President of Club Polk -
Get 1 seven channel amp & be done with it!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
