amp queston
goingganzo
goingganzo Posts: 2,793
edited December 2006 in Electronics
well it is upgrade time and i would like some advice
i want to upgrade my amp in my theater and would like some advice. should i go 4 2 channel amps or 1 7 channel amp?
i am looking for at least 200wpc 8 ohms and around 4k used for 4 two channel amps or new for 7 channel maybe used
my speakers are a custom buld with dual 6.5 in with xbl^2 and the vifa ring tweater like found in lsi but top of the line dome meteral.
Post edited by goingganzo on
    F1nut Posts: 51,997
    Four 2 channel amps would definitely be more impressive to look at, sonics may be better depending on the amps and if one goes down you're not totally SOL.
  • cfrizz
    cfrizz Posts: 13,415
    Get 1 seven channel amp & be done with it!
