Monitor 40's has 2 positives and 2 negatives?
funbags
funbags Posts: 3
I've had my Monitor 40's for a while now, and I forgot why are there two connections on the back of the speakers? (2 Reds, 2 blacks)
- John
Post edited by funbags on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited December 2006
    Top set for highs, bottom set for lows, connected together with brass straps to enable one speaker wire to be used.
  • funbags
    funbags Posts: 3
    Thank you!
    So as long as the brass is there, then both speakers are working i guess :)
    - John
  • Dennis Gardner
    You got it.........welcome to ClubPolk!
  • funbags
    funbags Posts: 3
    Thanks! - John
  • nadams
    nadams Posts: 5,877
    funbags
    hehehehe.
    Ludicrous gibs!
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    Those 40's will grow on you. Give them some break-in hours, than crank them up and blow the carbon out. :)
