Monitor 40's has 2 positives and 2 negatives?
funbags
I've had my Monitor 40's for a while now, and I forgot why are there two connections on the back of the speakers? (2 Reds, 2 blacks)
- John
- John
Post edited by funbags on
Top set for highs, bottom set for lows, connected together with brass straps to enable one speaker wire to be used.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Thank you!
So as long as the brass is there, then both speakers are working i guess
- John -
funbags wrote:So as long as the brass is there, then both speakers are working i guess
You got it.........welcome to ClubPolk!HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Thanks! - John
Those 40's will grow on you. Give them some break-in hours, than crank them up and blow the carbon out.
