Am i being lazy?
polktiger
Does anyone run 7.1 surround since most material is 5.1. I will be wiring our house for surround this weekend, so I will be under the house pulling the wire for the surround speakers and for Zone 2 (living room speakers), and I am trying to decide whether to go ahead and pull the wire for the 2 rear surround speakers to handle 7.1. I can use the speakers that I was going to use for those 2 extra surrounds elsewhere in the house.
Any thoughts? We are making big changes with the house. The last time I did HT work we were before DVDs and I was stoked about how awsome pro logic was. I have never even heard a 7.1 set-up so I am not sure if it is more hype than substance.
Post edited by polktiger on
Run it. even if you don't use it now, if you change your mind they will be there waiting for you.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
cfrizz wrote:Run it. even if you don't use it now, if you change your mind they will be there waiting for you.
exactly as Cathy said.. run it.. no one says you have to go 7.1 i think a lot of people run 5.1, 6.1 and of course some run 7.1 but material is limted.PolkFest 2012, who's going>?
all i do is listen to everything in 7.1. sucks having to scroll through my soundfield settings to get to plxII since everything is stuck in 5.1 la-la land. c'mon technological evolution........hurry up!
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
Run the wire while you have the chance.
just don't run any wire any thinner than cooked spaghetti.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
Run it. I wish I did...
Run the wire, you are already there, while your at it run some 75 ohm & cat5 what the heck you never know.
I wouldn't run it. 5.1 fits the bill for me.
Better to be proactive than reactive. Go for it.Michael
NORTH of 60° -
do it. If I had the chance I would, and all I have right now is a 5.1 avr
Most people i see eating spaghetti, they are the size of earthworms. Only angle hair for me.BIZILL wrote:just don't run any wire any thinner than cooked spaghetti.
Went from 5.1 to 6.1 to 7.1 - that was four years ago and i have never looked back. Seeing a system without side and rear surrounds seems VERY odd to me now........... -
I agree.scottvamp wrote:Went from 5.1 to 6.1 to 7.1 - that was four years ago and i have never looked back.
I will frequently switch to stereo, x6.1 (no center) and occasionally 4.1 (no center or surround). But I never use 5.1, 7.1 is better.Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70 -
Thanks all for your advice. I will go ahead and pull the wire. For those that expressed concern, it will be 12ga wire (from Blue Jeans, so not super elite stuff but ought to work well enough for my ears.):)
and you can thank us later when you utilize it as well. at that point, go ahead and pat yourself on the back for having been 'proactive' as michael/janmike suggested.
and scott, i'm gonna try to enjoy my next plate of spaghetti whilst clearing my mind of the thought of earthworms!
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
If you don't run it 7.1 will be the standerd next month. If you do, it will be years but you'll be set. Murphy's law.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880 -
MSALLA wrote:If you don't run it 7.1 will be the standerd next month. If you do, it will be years but you'll be set. Murphy's law.
Do you run the 7.1 with your RX-V2500? I just bought that unit on sale @ Tweeter and will be installing over the weekend. Do you like the unit, I will be running RTi4s and Monitor 30s (front & surround) with R15 as the rear. I assume the 2500 has enough power, but I was curious to know what you think. -
polktiger wrote:Do you run the 7.1 with your RX-V2500? I just bought that unit on sale @ Tweeter and will be installing over the weekend. Do you like the unit, I will be running RTi4s and Monitor 30s (front & surround) with R15 as the rear. I assume the 2500 has enough power, but I was curious to know what you think.
I should have read this before My last post. You have plenty of power to run those speakers. You won't have problems with anything unti you get up to the Rti12's. I had a set of rti6's and they sounded nice. I assume the 4's will also.If you running the 4's as mains make sure you get an i series center and not the monitor series. You want like a CSi3 0r csi5.
P.S. sorry about the post hi-jack.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
Harmony 880 -
No problem. I have an older CSi30. It used to match to the RTi28 and 38, so I am assuming it will go ok with the 4s.MSALLA wrote:I should have read this before My last post. You have plenty of power to run those speakers. You won't have problems with anything unti you get up to the Rti12's. I had a set of rti6's and they sounded nice. I assume the 4's will also.If you running the 4's as mains make sure you get an i series center and not the monitor series. You want like a CSi3 0r csi5.
