Acoustic Research vs. Signal Cable
jrlouie
I have some Acoustic Research Master Series speaker cables on my 2 channel setup...
http://www.accessories4less.com/cgi-bin/item/MS320
Do you think I would see a change in sound or would you consider it an upgrade going to some something like the Signal Cable Classics?
http://signalcable.com/classicspeaker.html
My girlfriend is just looking for Christmas gift ideas under or around $100
I'm only looking at new (not used) and from a reputable seller/retailer so it is easy for her to do the purchasing. She doesn't dig the "give me money and I'll buy it" philosophy
Which, I understand.
Post edited by jrlouie on
Try it... it's a win-win situation since Frank offers a 30-day moneyback guarantee.
As for the Master Series speaker cables, it is my understanding the "cable signal separator" actually introduces certain capacitance issues and therefore works against the product.I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore -
Well....I do have other things to put on the list, but they won't all fit. So I have to choose.
Hmm.....
Thanks for the feedback though. -
Buy cable risers.
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I just got some new Signal Cable Ultra speaker cables (last week) and BAM, right out of the bag, HUGE difference! I noticed a smaller improvement when I swapped my old IC's with Frank's IC's. I'm a believer now for sure.Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
your getting the advantage of the synergy withthe cables. Pretty neat, ain't it?
Yeah, I noticed an immediate and significant improvement when switching from my Monster Cables to my Acoustic Research.Halo wrote:I just got some new Signal Cable Ultra speaker cables (last week) and BAM, right out of the bag, HUGE difference! I noticed a smaller improvement when I swapped my old IC's with Frank's IC's. I'm a believer now for sure.
What cables did you previously have? -
Speaker cables I started with were of the RatShack, AR, Monster 14 - 16AWG. Then I switched to Blue Jeans Cable Ten White 10AWG. Last up was Signal Cable.
IC's were pretty much the same: RatShack, AR, Monster (different levels), audioquest, and finaly Signal Cable.
I'm not saying SC is the end for me but it was the most revealing upgrade so far.
Zebra cables and Cobalt cables were also on my list. Frank gives CP members a discount so it was a no-brainer for me.Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
