what speaker wire gauge would you recommand
Home Theatre
For 8 ohms?
Everything I own burned in the fire!!!!!!!!!!
Post edited by Home Theatre on
12-14 gauge seems to be the most common.
dane_peterson wrote:12-14 gauge seems to be the most common.
True.
However, most entry level receiver based HT systems will work just fine with 16 or even 18 gauge if the runs are less than say 50' long. -
I got Monster Cable15.24m.Everything I own burned in the fire!!!!!!!!!!
Home Theatre wrote:For 8 ohms?
If one wants to spend the $ , then get the best! Certain products make an in- expensive product sound like a much more hi-end product, for a lot less... but be carefull ...sometimes you can outspend your product that another will outperform out of the box ...for instance - i have a very old Pioneer PD- DM 802 CD 12 Changer that , for fun , I connected to a Musical Fidelity X-10D, Kimber Silver interconnects(4) , and Kimber8TC speaker cables, all going thru a Panamax 1000 and a Yamaha RX V870 Reciever and Polk Monitor 30's with an Infinty powered sub. Just for CD and vinyl playback. I did this because I had extra toys while I await new toys ... this setup blew away anything I heard under $4 000...for 1/2 the price!! -
12 guage.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
10 gauge
Audio Physic Scorpio II
Pathos Logos
MIT Shotgun S3
Bada HD-22 CDP -
I vote 16 -> 14 gauge.Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
For long runs I would not go under 12ga. For short runs you can get away with 16, but I always use 12.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880 -
Zero, why would the gauge affect the emphasis of the sound? I'm talking about decent gauge, acceptable cables.UNIVERA
Historic Charleston SC
2 Channel:
SDA-SRS's RDO tweets
Biamped Anthem 2 SE's w/1970's NOS Siemens CCA's
Anthem Pre 2L w/E.harmonix platinum matched 6H23's
CDP- NAD C 542
HT setup:
AVR: NAD T 773
Rears: Polk LC80i
DVD: Toshiba 3109 dual tray
Subs: Velodyne and M&K
T.V.: Sony KDL-52XBR4 w/Vans Evers Clean Line Jr.
Conditioner: Panamax M5100EX
Master Bedroom Sony 40KDL-XBR3
"I love it when a plan comes together." Hannibal Smith, The A-Team -
Might check out this old thread that I started last year.
In the second post there is a link to a guide showing safe lengths based on load and gauge.
http://www.polkaudio.com/forums/showthread.php?t=34835HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500, -
I've had the best results (to my ears) with 12 AWG - it tightened up the bass noticably to me. Right now I am using AR oxygen free. I am certain there is better out there, but the price seemed right and it was easily had at BestBuy.
YMMV
C-HT Rig
Polk SDA SRS 2.3tl - Anthem 2 SE
Polk CSi5 - Adcom 555
Polk Monitor 30 - HK DPR1005
SVS PB12 ISD/2
Denon DCD-1500II
Sony SXRD 60"
ShengYa CS-10
Basement Rig
Polk SDA SRS2
Carver 1.5t
Carver C2
Technics SLD202
Some Other Sony DVD/CDP -
seo wrote:
750 kcmil
sorry, couldn't resist
1000 MCM tri-twist - if your gonna go BIG, might as well out all the stops! Of course you'll likely need to trench it.
Do you hear that buzzing noise?
It aint called Monster for nothin!
