what speaker wire gauge would you recommand
Home Theatre
Home Theatre Posts: 469
edited December 2006 in Speakers
For 8 ohms?
Everything I own burned in the fire!!!!!!!!!!
Post edited by Home Theatre on
  • dane_peterson
    dane_peterson Posts: 1,903
    edited November 2006
    12-14 gauge seems to be the most common.
  • BobMcG
    BobMcG Posts: 1,585
    True.
    However, most entry level receiver based HT systems will work just fine with 16 or even 18 gauge if the runs are less than say 50' long.
  • Home Theatre
    I got Monster Cable15.24m.
  • BobMcG
    BobMcG Posts: 1,585
    They'll do just fine.
  • mfeehl
    mfeehl Posts: 7
    For 8 ohms?
    If one wants to spend the $ , then get the best! Certain products make an in- expensive product sound like a much more hi-end product, for a lot less... but be carefull ...sometimes you can outspend your product that another will outperform out of the box ...for instance - i have a very old Pioneer PD- DM 802 CD 12 Changer that , for fun , I connected to a Musical Fidelity X-10D, Kimber Silver interconnects(4) , and Kimber8TC speaker cables, all going thru a Panamax 1000 and a Yamaha RX V870 Reciever and Polk Monitor 30's with an Infinty powered sub. Just for CD and vinyl playback. I did this because I had extra toys while I await new toys ... this setup blew away anything I heard under $4 000...for 1/2 the price!!
  • Early B.
    Early B. Posts: 7,900
    12 guage.
    "God grooves with tubes."
  • Lsi9
    Lsi9 Posts: 616
    10 gauge
    Audio Physic Scorpio II
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
  • seo
    seo Posts: 305
    ;) 750 kcmil ;)
    sorry, couldn't resist
    Signature goes here
  • TheReaper
    TheReaper Posts: 636
    I vote 16 -> 14 gauge.
    Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
  • MSALLA
    MSALLA Posts: 1,602
    For long runs I would not go under 12ga. For short runs you can get away with 16, but I always use 12.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
  • univera
    univera Posts: 848
    Zero, why would the gauge affect the emphasis of the sound? I'm talking about decent gauge, acceptable cables.
    UNIVERA
    Historic Charleston SC
    2 Channel:
    SDA-SRS's RDO tweets
    Biamped Anthem 2 SE's w/1970's NOS Siemens CCA's
    Anthem Pre 2L w/E.harmonix platinum matched 6H23's
    CDP- NAD C 542
    HT setup:
    AVR: NAD T 773
    Rears: Polk LC80i
    DVD: Toshiba 3109 dual tray
    Subs: Velodyne and M&K
    T.V.: Sony KDL-52XBR4 w/Vans Evers Clean Line Jr.
    Conditioner: Panamax M5100EX
    Master Bedroom Sony 40KDL-XBR3
    "I love it when a plan comes together." Hannibal Smith, The A-Team
  • cmy330go
    cmy330go Posts: 2,341
    Might check out this old thread that I started last year.
    In the second post there is a link to a guide showing safe lengths based on load and gauge.
    http://www.polkaudio.com/forums/showthread.php?t=34835
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • bert26
    bert26 Posts: 320
    I've had the best results (to my ears) with 12 AWG - it tightened up the bass noticably to me. Right now I am using AR oxygen free. I am certain there is better out there, but the price seemed right and it was easily had at BestBuy.
    YMMV
    C-
    HT Rig
    Polk SDA SRS 2.3tl - Anthem 2 SE
    Polk CSi5 - Adcom 555
    Polk Monitor 30 - HK DPR1005
    SVS PB12 ISD/2
    Denon DCD-1500II
    Sony SXRD 60"
    ShengYa CS-10
    Basement Rig
    Polk SDA SRS2
    Carver 1.5t
    Carver C2
    Technics SLD202
    Some Other Sony DVD/CDP
  • Monster Jam
    Monster Jam Posts: 919
    seo wrote:
    ;) 750 kcmil ;)
    1000 MCM tri-twist - if your gonna go BIG, might as well out all the stops! Of course you'll likely need to trench it. ;)
    Do you hear that buzzing noise? :confused:
  • solidclub
    solidclub Posts: 39
    It aint called Monster for nothin!
