age old ? bi-amp
whitetruk
i`am using mono`s now,with the ai1 cable.? is, can i use a stereo amp also,say for the upper freq.
huge problem having to many amps (gotta luv it)
later ,scott
sorry the above question is for a pair of large srs`s
later ,scott
I thought it was fairly amusing also. The Polk Ogre doesn't always get 'it'
Post edited by whitetruk on
whitetruk wrote:i`am using mono`s now,with the ai1 cable.? is, can i use a stereo amp also,say for the upper freq.
later ,scott
What?Lovin that music year after year.
Main 2 Channel System
Polk SDA-1B,
Promitheus Audio TVC SE,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
IXOS XHA305 Interconnects
Computer Rig
Polk SDA CRS+,
Creek Audio 5350 SE,
Morrow Audio MA1 Interconnect,
HRT Music Streamer II -
i`am using mono amps,i was wondering if it is possible to use a stereo amp also.mono`s on the bottom,stereo amp on the top.
not sure with the common ground thing,maybe i need to use 4 monoblocs.
currently using the ai1 interconnect cable, sda srs 1.2tlI thought it was fairly amusing also. The Polk Ogre doesn't always get 'it' -
yes, you can bi-amp them.
RT1 -
rt1,is that possable with two mono`s and a stereo amp??
thanxI thought it was fairly amusing also. The Polk Ogre doesn't always get 'it' -
If you like call Ken Swauger at Polk CS he is the man for SDA. As long as you are using the AI-1 and have removed the binding straps you can bi-amp the 1.2TL, how you bi-amp is up to you. If your preamp does not have dual outputs you will need to y-cable out.
RT1 -
as long as you have the a1 cable, you should be fine. with that cable you can have a monoblock for the upper and ;ower of each speaker if you want, common ground no longer an issue. cant see why a stereo amp on the tops should be an issue if running monos for the bottom. call Ken though, it cant hurt.Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
To really make this worthwhile, you should pick up some f-mod pseudo active crossovers... I don't know if they make them at the recommend points for SDA's (300 HP, 4.5k LP), but as long as you get filter out the lows going the tweeter amplifier, you should hear some improvement.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i
