Next Upgrade from Lsi series
pmckeealaska
pmckeealaska Posts: 808
edited November 2006 in Speakers
I am perfectly happy with my LSi setup now, but if one was looking to upgrade to new speakers, what would be the best place to start looking for a brand and still spend say less than 10K for a pair of speakers that would be a step up from the LSi? Any suggestions?
Music and Movie Rig
Samsung 40" HDTV 1080p
LSi25 Front Speakers
LSiC Center Channel
LSiFX Surrounds
Rotel RB 1080 2-Channel Amp
NAD T763 Reciever
Denon DVD 2900 Universal Player
Audiosource 10 Band Digital Equalizer
Audioquest CV-8 speaker cables
Audioquest Sub-X subwoofer cables
Audioquest King Cobra Interconnects
Monster AVS 2000 Voltage Stabilizer
Playstation 3 120GB Slim
Post edited by pmckeealaska on
  • MikeC78
    MikeC78 Posts: 2,315
    :)Ask Joey V...
    Martin Logan's is a good start, or some Von S's. There are various options depending on taste. IMO, I'd probably get the ML summits. Those are some sweet sounding speakers!
    Mike
  • jm1
    jm1 Posts: 618
    If I was looking for a PAIR or speakers and had up to 10K of a budget with your system, I would first start replacing/complementing some of the existing components. By stating a pair of speakers and not knowing exactly your ultimate intent, a two channel upgrade path could be:
    NAD T763 Receiver -> add a two channel pre with HT pass through
    Rotel RB 1080 2-Channel Amp -> upgrade to a more refined amp (does not imply more watts; it may have less than the 1080)
    Denon DVD 2900 Universal Player -> external DAC or dedicated player
    With the money left over, sell the front and center speakers and upgrade to a brand of speakers for L+R duty and buy a matching center from the same manufacturer. The LSiFX will be more than adequate for HT duties. Your current LSi speakers leave you some room to upgrade other parts of the system and still enjoy the benefits of the new components.
    To answer your original question, what Zero said.
    Just some quick thoughts.
    All truth passes through three stages. First, it is ridiculed, second it is violently opposed and third, it is accepted as self evident.
    Arthur Schopenhauer
  • madmax
    madmax Posts: 12,434
    LSi's should carry you for awhile. I would add a preamp for two channel use only if that is one of your goals.
    madmax
    Vinyl, the final frontier...
    heiney9 Posts: 25,408
    Gear to compliment $10K speakers has to be a consideration. Look at the whole package and go that route not just one part of the package. The Lsi's are damn nice (not without their minor faults). What I've found in this hobby is you usually you move from one compromise to another. There is no holy grail. Certainly some combination's are better than others but it's the system synergy you should be concerned with.
    Before you consider moving up the speaker chain you should address the components and especially your source. The source is where it all starts at.
    YMMV
  • Joey_V
    Joey_V Posts: 8,600
    MikeC78 wrote:
    :)Ask Joey V...
    Mike
    Thanks for the comment!
    As for my opinion... there are several that I would look at, even some beyond the ML brand.
    1. Martin Logan Summit
    2. Wilson Sophia
    3. Magnepan 20.1
    4. Innersound Kachina Reference
    5. BW 802D
    6. Sonus Faber Cremona
    7. Audio Physic Avanti
    8. Vandersteen 5a
    Those are the ones I like, in no particular order....
    However, there are others that stand out with others as the speaker for them... like the VS.... they make the Von Schweikert VR4SR, which is supposed to be killer from what I read.
    There are more speakers out there that might tickle you better than anything I listed... but no man can ever hear them all.
    I will add... front end equipment is just as important as the speakers you are putting infront of you. If you are serious about $10K speakers, then you better be open to the possibility of putting out another $10K on amps, preamps, and CDP.
    JOey
  • McLoki
    McLoki Posts: 5,231
    As a few brands that make very worthwhile contenders for your more expensive speakers tastes,
    Magnepan
    Dynaudio
    Vandersteen
    All offer excellent speakers with a different sound than you would get from the LSi's.
    Michael
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    Nice suggestions guys!................It is refreshing to see reasonable, sane, thought processes surface when someone asks for the next upgrade path. I agree that I wouldn't throw more $$$ on speakers as the next upgrade.
    Your HT system has a great amount of balance as it is if you would add a nice fat SVS or similar sub. This would make your HT a 9 out of 10 in most people's books.
    For a 2 channel rig that would rival your HT, I would change out the Denon and Rotel gear for dedicated CD/LP and some tubes in either a preamp or integrated amp regardless of your speaker choices.
    At the $$$ level you are at, you deserve to have dedicated rigs, or choose components as if they were going to be used that way, not for how good they are at double duty.
    Just my thoughts....
  • wingnut4772
    wingnut4772 Posts: 7,519
    Definitely audition some Von Schweikerts. Make sure they are well broken in becuase it's a different speaker if it's not.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • ohskigod
    ohskigod Posts: 6,505
    definitly put me in the "throw that money in the electronics" camp. those LSi's have more to give you with a beefy amp, and improvement in preamplification.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • Midnite Mick
    Midnite Mick Posts: 1,591
    I agree with the others regarding the electronics for improvements especially if you do in fact like the lsi's. However, in the speaker realm I think that Usher offer very good bang for the buck. I think one can find models pretty close to the price of the lis's that sound very good. Totally different speaker than the lsi's.
    Just my thoughts,
    Mike
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • wingnut4772
    Having owned the LSis and now the Von Schweikert VR4 Jrs I can tell you that electronics will only make so much difference. The LSIs are good but there are much more rewarding speakers available if you want to up the budget.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • LuSh
    LuSh Posts: 887
    Sure there are wing, but his electronic's are holding him so far back even with the LSi's why waste money on better speakers? He'd be better off getting a new source and at least a top flight intergrated. I'd take LSi15's with a VAC Avatar intergrated, Museatex digital front end then a pair of VR 4jr's with his NAD/Rotel combo with a denon front end.
  • cfrizz
    cfrizz Posts: 13,415
    I too would also start with upgrading other components before getting different speakers. Start looking at getting a prepro rather than a receiver. Also consider getting a 5-7 channel 200wpc or more amp for all of your speakers! All those LSI's will apreciate the extra power.
  • mantis
    mantis Posts: 17,322
    For Lsi money, there isn't much better if any. Maybe some personal tastes but I think they can hang with anything in there price class.
    There are 2 many better speakers on the market to list them. I went from Lsi to Dynaudio and I don't look back.
    A also agree with Martin Logan. If I didn't own Dynaudio, I may own Martin Logan. There speakers and subs are some of the very best I have heard. There subs are so musical.
    Dan
    Dan
  • Phasearray
    Phasearray Posts: 437
    This post makes me realize how poor I am
    Receiver - Onkyo HT-R340
    Front - Pioneer S-HF21
    Center -Onkyo SKC-340C
    Surround Back - Polk R15 <--Ticket to club polk
    Subwoofer - Onkyo SKW-340
  • Phasearray
    4 LSI (2front 2 back) is my goal! Can't believe there are people who wants to upgrade out of them!
  • Joey_V
    Joey_V Posts: 8,600
    Hey man...
    There are people who want to upgrade from whatever they upgraded to from the LSi.
    It's a crazy world, my friend!
    Joey
    PS
    I want the next level Martin Logan above mine, once it comes out in 2 years. :)
  • Phasearray
    Joey_V wrote:
    Hey man...
    Joey
    PS
    Garsh, Martin Logan cost more than my car.
  • Joey_V
    Joey_V Posts: 8,600
    Yup... and it's worth it.
    (Though I will confess that I bought them used, I cant afford new! Heheheh)
  • ohskigod
    I've gone through a number of levels of amplification for my LSi's, and I heard big deiierences between
    I went from a 60 watt X 2 Rotel 960, to a 2 X 120 (200 into 4 ohm) Rotel 980, to Outlaw monoblocks at 300 watts into 4 ohms, then to a Carver m4.0t (or currently a Hafler DH500) 500Watts into 4 ohms. Every step, the Lsi's gave more. upgrading speakers before the electronics wopuld be pure silliness.
    to me, the LSi's really seemed to like the Carver. the only reason they are still not on the Carver, is because I need it to power my Carver Amazing speakers.
    The 500 watts from the Hafler is doing them just fine in my theater currently
  • Monster Jam
    Monster Jam Posts: 919
    My 5 LSi speakers have a higher resale value than the car I drive to work!
    Do you hear that buzzing noise? :confused:
  • markmarc
    markmarc Posts: 2,309
    First try improving the room acoustics if you haven't already (WAF, of course). You'd be amazed at how much better your current setup will sound.
    Now, if that has been done, I'd having your universal player modified, for $4-600 dollars you will hear a vast improvement in sound.
    Former Staff Member TONEAudio
    2 Ch. System
  • janmike
    janmike Posts: 6,146
    Proac.
    Michael ;)
    NORTH of 60°
  • ohskigod
    excellent point. the treatments I did in my basement for my 2 channel were apparent to many of my friends during our weekly poker game, most of which do not exactly have trained ears.
  • josh_parsons626
    josh_parsons626 Posts: 219
    Amen brother! LOL
    Don't forget to look at My Home Theater :D
    Receiver - Onkyo TX-SR503
    Fronts - Polk Audio Monitor 40
    Center - Polk Audio CS1
    Surrounds - Paradigm Cinema ADP
    Subwoofer - Velodyne VRP-1200
