Cable suggestions for Outlaw m2200
ntg
I just ordered 2 m-2200's for my main speakers and I noticed I have a set of Monster RCA type plugs.These are 2 connected wires 4 RCA plugs with an arrow in one direction with gold plated connectors.I take it these will work and if not what cables would you suggest for the reciever preouts to the amp?
Post edited by ntg on
It really depends on your budget. Many here select the likes of Signal Cable, Audioquest, Blue Jeans Cable. Personally I have SC for my entire HT.Michael
NORTH of 60° -
they will work, I will be using AQ sidewinders for now then I might order from signal cable.
I highly recommend the DH Labs Air Matrix.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Outlaw cables seem to work just fine.polkaudio SRS (rdo194 x 8)
Dodd ELP (separate power supply)
JC 1 blocks ( strapped )
Rega Apollo
MIT (speaker cables) Outlaw (ICs)
polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
B&K 505
Samsung LCD
VIP 622
HSU STF-2 -
Thanks for the input.
I also have been trying to find out some info on surge protection and want to know what you guys with 3-4 amps do.
I have seen lots of conditioners and protectors with 2 high current plugs but thats about it??
