Cable suggestions for Outlaw m2200
ntg
ntg Posts: 36
I just ordered 2 m-2200's for my main speakers and I noticed I have a set of Monster RCA type plugs.These are 2 connected wires 4 RCA plugs with an arrow in one direction with gold plated connectors.I take it these will work and if not what cables would you suggest for the reciever preouts to the amp?
Post edited by ntg on
  • janmike
    janmike Posts: 6,146
    edited October 2006
    It really depends on your budget. Many here select the likes of Signal Cable, Audioquest, Blue Jeans Cable. Personally I have SC for my entire HT.
    Michael ;)
    NORTH of 60°
  • Willow
    Willow Posts: 11,233
    edited October 2006
    they will work, I will be using AQ sidewinders for now then I might order from signal cable.
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited October 2006
    I highly recommend the DH Labs Air Matrix.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • read-alot
    read-alot Posts: 812
    edited October 2006
    Outlaw cables seem to work just fine.
    polkaudio SRS (rdo194 x 8)
    Dodd ELP (separate power supply)
    JC 1 blocks ( strapped )
    Rega Apollo
    MIT (speaker cables) Outlaw (ICs)
    polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • ntg
    ntg Posts: 36
    edited October 2006
    Thanks for the input.
    I also have been trying to find out some info on surge protection and want to know what you guys with 3-4 amps do.
    I have seen lots of conditioners and protectors with 2 high current plugs but thats about it??
