Newbie - Just Joined
Grungewort
Hello all,
I'm a student and on a very tight (prohibitevly so) budget. Here's the deal: I just picked up Monitor 30s on sale and love the sound - although not having a subwoofer is of course noticeable and I'm having a slight imaging problem as the table is too low and not quite wide enough given my 24inch t.v . I'm wondering if anyone has suggestions for improvement. I bi-wired into the B speaker outputs of my stereo receiver (Yamaha rx 397) and didn't notice a low end improvement although I detect (at times) crisper highs. I'm also saving up for a turntable so any advice in that department would be helpful too.
Post edited by Grungewort on
move your Monitor 30's away from the back wall if they are close up to it. sometimes moving them away from each other.. about 6ft or more may help.PolkFest 2012, who's going>?
No, you attempted to Bi-amp, but most receivers will cut the rated output in half if you select both A & B speakers.Grungewort wrote:I bi-wired into the B speaker outputs of my stereo receiver (Yamaha rx 397) and didn't notice a low end improvement although I detect (at times) crisper highs.
Oh yeah, Welcome! -
Frank Z wrote:No, you attempted to Bi-amp, but most receivers will cut the rated output in half if you select both A & B speakers.
Hmmm, I am certainly no expert, but i thought the benefit from bi-wiring was (at least in part) that the signal for the lows wasn't included in the same wire as those for the highs -in which case what i did should have been successful - no? [used the B speaker outputs on Receiver to run wire to the second inputs on the Mon. 30s] If not, what, if anything, can i do with the already cut wire? Anyway, I'm not too worried about cutting the rated output because these speakers are sooo efficient.
Also, any suggestions on a decent turntable> - I've got some high quality bootlegs of Hendrix and Hot Tuna that I've been dieing to listen to for over a year...
I am fairly new to all this indeed, so please let me know when I'm being stooopid. -
Some light reading for you...
http://www.polkaudio.com/forums/showthread.php?t=25622&highlight=bi-wire+Bi-amp
http://www.polkaudio.com/forums/showthread.php?t=15782&highlight=bi-wire+Bi-amp
And if you're really bored...
Read all of these! -
Hey Frankz,
Thanks for those links, definitely a big help. The second one was really helpful, especially the pic. I understand bi-wiring now. I see how what I've done has been referred to as ghetto-bi-amping....
You seem to be really knowledgable, any suggestions for <$150 turntable? -
In that price range you're in the ebay/used TT arena...no help here. I can highly recommend Music Hall. I've got a MMF2.1 that I'm very pleased with.
Welcome to the club !
Welcome aboard , grungewart
JC approves....he told me so. (F-1 nut) -
Welcome!:) You might consider getting stands for the 30s so you can place them perfectly.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Welcome Grungewart!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
