For all with a digital Radio Shack spl
Jer_ry wrote:bump....curious to know if anyone elses sub is almost off to get it at 80db. I have a svs pb10
If your sub channel is set too high on your receiver, the sub amp setting will be set lower. Make sure your crossover isn't set too high..... 80 hz or below.
A balanced sub is one that doesn't draw any attention to itself during music or movies on normal passages. You shouldn't be able to tell when the speakers hand off to the sub. Too many people tend to boost the bass for effect.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
The level for the sub is set to 80hz and the sub volume on the avr is as low as it goes I had to go adjust the volume on the sub to get it 80db and it's at 8 o clock. Turned it to about 10 o clock and I can tell it's there.
I guess thats what it is then. I'm used to hearing it and like the effect.Dennis Gardner wrote:A balanced sub is one that doesn't draw any attention to itself during music or movies on normal passages. You shouldn't be able to tell when the speakers hand off to the sub. Too many people tend to boost the bass for effect. -
Dennis Gardner wrote:If your sub channel is set too high on your receiver, the sub amp setting will be set lower. Make sure your crossover isn't set too high..... 80 hz or below.
crank it!!!!!!!!!!!!
I know what you mean though... my stupid **** friend. has his sub cranked up so high... you just get pounded with bass on entire songs and soundtracks.. even commericals... you get hit with to much bass
I have mine set just slightly higher than what the SPL meter says.. and during the right passages on soundtracks.. it hits deep and hard. otherwise. it's just fine for most things i listen to .PolkFest 2012, who's going>?
Tubes Rule
Digititis drools like an ol'e Bulldog on a hot summer day with no breeze.
Glad you got your meter squared away. -
Tubes SUCK, Transistor RULES.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
You're in the dinasaur dying column RT! You can say it rules all you want, but you will always just be in a little barely accomadated niche who gets looked at funny & laughed at!:p
Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Cathy, you should be updating your some add a Tube pre amp. Become a Dinosaur member Dinosaur lover
It's on my short list.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
I don't want no effen tubes! SS all the way. Give me lots of power, lots of low maintenance & decades of use!!!:DMarantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
You should add a Tube Pre-amp, pre amp driving a SS amp. You got better sound with all the power you wish for.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
