Frequency for dummies
ntg
ntg Posts: 36
edited October 2006 in Speakers
Do they make a book Frequency for dummies or a web site for understanding most of this stuff?
Every time I start reading the threads here and think I am starting to under stand things you guys throw in some graph and I am done:confused:
Where do the graphs come from and how many different measuring devices does one have:eek:
Thanks from stupidville
Post edited by ntg on
  • PolkThug
    PolkThug Posts: 7,532
    edited October 2006
  • steveinaz
    steveinaz Posts: 19,545
    edited October 2006
    Frequency response is a measure of a components ability to reproduce a certain frequency range, with all frequencies as equal as possible in level (amplitude). Human hearing is believed to be in the range of 20 Hertz (Hz=cycles per second) to 20,000 Hertz. 20Hz being very low frequency (bass--think: rolling thunder) and 20kHz being very high frequency (treble--think: the hissing of steam). Realistically speaking, your "average" 40 year old male probably has a range of 20Hz-14kHz.
    Measuring involves using a "control" which would be a reference level, say 90 decibles, and then seeing how close all of the frequencies can be reproduced at that reference level. This tells you how linear the response is, in other words--if all the frequencies are being reproduced at the same level (ideally), and if not, what is the deviation in dB (decible) of each charted frequency.
    Ideally you want your equipment to reproduce this frequency range with as little deviation in level between frequencies as possible (+/-3dB in level), though it's easier said than done, and generally, the more "accurate" the equipment, the more expensive it is. It is especially difficult (and EXPENSIVE) to build a speaker that covers the full range of frequencies, because of speakers electro-mechanical nature and interaction with the listening room. Most speakers can attain the necessary high frequencies, but getting super-low bass is far more of a challenge.
    Summing up, generally you like to see a specification like: 20-20kHz, +/- 3dB, but again, very few speakers can dig down to 20Hz, sans sub woofers.
    Remember: Specifications only tell half the story. They speak more to performance capability than they do to the actual sound of the component. There are many components that measure well, but sound like ****; and likewise there are components that don't have fabulous specifications that sound very good. Let your ears be the final judge.
  • Skynut
    Skynut Posts: 2,967
    edited October 2006
    Nice Steve, I get confused on these things also.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • sunil3478
    sunil3478 Posts: 17
    edited October 2006
    Good explanation
    thanks
  • madmax
    madmax Posts: 12,434
    edited October 2006
    The best way to get a really good feeling for frequency is to get a graphic equalizer and play with it. After awhile you will be able to say things like "I hear a hiss around 13 Khz". :)
    madmax
    Vinyl, the final frontier...
  • PolkThug
    edited October 2006
    ...and before you know it, you've got a mic, pre-amp, laptop and true rta level 4 and are analyzing the resonating frequency of every object in the room. ;)
  • JKnPA
    JKnPA Posts: 41
    edited October 2006
    Graphs are plots of two different parameters. One parameter is on the 'vertical' scale, the other is on the 'horizontal' scale. Looking at a graph can tell you a lot of information , much easier than trying to express the results in words!
    This link shows a graph of speaker impedance vs. frequency.
    Notice how the speaker impedance( vertical scale) changes as the frequency source( horizontal scale) changes. Notice the 'nominal impedance' is taken from the flat portion of the chart...........:rolleyes:
    http://en.wikipedia.org/wiki/Electrical_characteristics_of_a_dynamic_loudspeaker
    Cheers....
    Jk
    Denon 1906AVR
    Polk... M40s, Cs1
    JVC DVD player XV-SA600
    Sharp LC-37D6U
  • Holydoc
    Holydoc Posts: 1,048
    edited October 2006
    Steve,
    Kudos on the explaination. Great job!
    Holydoc (Home Theatre Lover)
    __________________________________________
    Panasonic -50PX600U 50" Plasma
    Onkyo -TX-NR901 Receiver
    Oppo -Oppo 980HD Universal DVD Player
    Outlaw -770 (7x200watt) Amplifier
    PolkAudio - RTi12 (Left and Right)
    PolkAudio - CSi5 (Center)
    PolkAudio - FXi3 (Back and Surround)
    SVS - PB-12/Plus (Subwoofer)
    Bluejean Cables - Interconnects
    Logitech Harmony 880 - Remote
  • steveinaz
    edited October 2006
    Gracias.
  • michael_w
    michael_w Posts: 2,813
    edited October 2006
    If you have an spl meter and a laptop (or close enough desktop) give a program called Room EQ Wizard a shot. It's free and can be pretty fun and useful to play around with.
  • Ern Dog
    Ern Dog Posts: 2,237
    edited October 2006
  • Deadof_knight
    Deadof_knight Posts: 980
    edited October 2006
    frequencies are all good but the resonances are a pain to deal with in a big room. Sometime they sound better in a room than out as Steve is trying to expain. The speaker you listen too must all be compared in the same way. or you have no true idea in how they sound. They sounded good at the stereo shop yet they sound less than desirable in your living room. The sonics of the environment have changed greatly.
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
  • steveinaz
    edited October 2006
    frequencies are all good but the resonances are a pain to dea l with in a big room
    Absolutely, the room is a component of the speaker no doubt. You want to hear speakers at their best, take them outside, with no walls to reflect or room resonances **** things up. I tried my speakers out on the patio once, they sounded wonderful---wish I could replicate that in the house.
