Frequency for dummies
Do they make a book Frequency for dummies or a web site for understanding most of this stuff?
Every time I start reading the threads here and think I am starting to under stand things you guys throw in some graph and I am done
Where do the graphs come from and how many different measuring devices does one have:eek:
Thanks from stupidville
Post edited by ntg on
Frequency response is a measure of a components ability to reproduce a certain frequency range, with all frequencies as equal as possible in level (amplitude). Human hearing is believed to be in the range of 20 Hertz (Hz=cycles per second) to 20,000 Hertz. 20Hz being very low frequency (bass--think: rolling thunder) and 20kHz being very high frequency (treble--think: the hissing of steam). Realistically speaking, your "average" 40 year old male probably has a range of 20Hz-14kHz.
Measuring involves using a "control" which would be a reference level, say 90 decibles, and then seeing how close all of the frequencies can be reproduced at that reference level. This tells you how linear the response is, in other words--if all the frequencies are being reproduced at the same level (ideally), and if not, what is the deviation in dB (decible) of each charted frequency.
Ideally you want your equipment to reproduce this frequency range with as little deviation in level between frequencies as possible (+/-3dB in level), though it's easier said than done, and generally, the more "accurate" the equipment, the more expensive it is. It is especially difficult (and EXPENSIVE) to build a speaker that covers the full range of frequencies, because of speakers electro-mechanical nature and interaction with the listening room. Most speakers can attain the necessary high frequencies, but getting super-low bass is far more of a challenge.
Summing up, generally you like to see a specification like: 20-20kHz, +/- 3dB, but again, very few speakers can dig down to 20Hz, sans sub woofers.
Remember: Specifications only tell half the story. They speak more to performance capability than they do to the actual sound of the component. There are many components that measure well, but sound like ****; and likewise there are components that don't have fabulous specifications that sound very good. Let your ears be the final judge.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2 -
Nice Steve, I get confused on these things also.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
Good explanation
thanks -
The best way to get a really good feeling for frequency is to get a graphic equalizer and play with it. After awhile you will be able to say things like "I hear a hiss around 13 Khz".
...and before you know it, you've got a mic, pre-amp, laptop and true rta level 4 and are analyzing the resonating frequency of every object in the room.
Graphs are plots of two different parameters. One parameter is on the 'vertical' scale, the other is on the 'horizontal' scale. Looking at a graph can tell you a lot of information , much easier than trying to express the results in words!
This link shows a graph of speaker impedance vs. frequency.
Notice how the speaker impedance( vertical scale) changes as the frequency source( horizontal scale) changes. Notice the 'nominal impedance' is taken from the flat portion of the chart...........:rolleyes:
http://en.wikipedia.org/wiki/Electrical_characteristics_of_a_dynamic_loudspeaker
Cheers....
JkDenon 1906AVR
Polk... M40s, Cs1
JVC DVD player XV-SA600
Sharp LC-37D6U -
Steve,
Kudos on the explaination. Great job!Holydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote -
Gracias.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
If you have an spl meter and a laptop (or close enough desktop) give a program called Room EQ Wizard a shot. It's free and can be pretty fun and useful to play around with.
frequencies are all good but the resonances are a pain to deal with in a big room. Sometime they sound better in a room than out as Steve is trying to expain. The speaker you listen too must all be compared in the same way. or you have no true idea in how they sound. They sounded good at the stereo shop yet they sound less than desirable in your living room. The sonics of the environment have changed greatly.:cool: " He who dies with the most equipment wins Right ? "
Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center,HPSA-1000 18" sealed DiY home sub.:D
Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables -
Deadof_knight wrote:frequencies are all good but the resonances are a pain to dea l with in a big room
Absolutely, the room is a component of the speaker no doubt. You want to hear speakers at their best, take them outside, with no walls to reflect or room resonances **** things up. I tried my speakers out on the patio once, they sounded wonderful---wish I could replicate that in the house.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
