Possible Speaker Stand Project
Early B.
I purchased a set of table legs off ebay recently. After I bought them, I figured a pair of them would make great speaker stands.
They are hardwood, square fluted and reeded legs that measure 6 in. x 6 in. and 28 inches long. These are hollow inside (for adding lead shot!?) and the boards that make up the square legs are 1 1/2 inches thick and are locked together with a spline type joint.There is a board on top that is 8.75 in. square. Each leg weighs about 17 lbs. These legs are well made and look very nice.
To make them into speaker stands, all I'd need to do is add a bottom plate with spikes, and maybe some sort of top plate to cover the screws. I'd love to dress them up with marble or granite top and/or bottom plates, but have no idea how to attach them without drilling holes in the plates.
Any ideas would be appreciated. Thanks.
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Post edited by Early B. on
you are an odd cookie...
Get some liquid nail (not caulk) and put it on the inner edge of the bottom of the leg... clamp it on and that bottom will never come off...ever...
But be prepared with a knife and a wet rag just in case it leaks out to the exterior - that stuff is a BEATCH to sand off. Near impossible.
If you dont think that will work, Id go a next step up in glue and get subfloor glue... which is even stronger. We've attached a porch post to brick steps (3 years ago) with it...
Its still there. haha- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Brad
Are you going to the gathering????- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Vr3MxStyler2k3 wrote:you are an odd cookie...
Glue? Really?
We're talking about some wood holding onto approx. 10 lb. slab of granite on each end. I'm not saying it won't work, but I don't trust glue. Maybe glue has come a long way in the past few years, I dunno. Sub-floor glue, huh? OK, I'll check it out. I hope you're right 'cause that's too damn easy. Even a guy like me can glue some **** together real good.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Vr3MxStyler2k3 wrote:Brad
Hell, no. I wouldn't be caught dead hangin' out with a bunch of delinquents.:eek:HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
You'd be amazed at what liquid nails will hold. Even if it didn't hold that well, gravity is working for you here.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
unc2701 wrote:You'd be amazed at what liquid nails will hold. Even if it didn't hold that well, gravity is working for you here.
OK, you guys are the experts. I'll try it.
It'll take ne a while to find the granite I want. I could easily do wood plates, but I want something a little more eccentric. Mybe a deep reddish/brown color with minimal striations.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Granite would look great on there- The other nice thing is that everytime you switch up materials you increase the structure's resistance to resonate/transmit vibrations. Granite/something not wood is deffinitely a good idea.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
If you are afraid of liquid nails....
Get subfloor glue...
That stuff is basically concrete in a tube. Im not lieing.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Early B. wrote:Hell, no. I wouldn't be caught dead hangin' out with a bunch of delinquents.:eek:
WHAT?????????????- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
So how could I install spikes?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Where are you getting the granite? If you buy it from a store that does countertops, those guys can drill out a few hole in the bottom then fill them with epoxy. You can then drill whatever you want into it. This is what they do in spots where you'd need to screw something to the countertop (ie straps for the dishwasher) Show them some t-nuts and tell 'em what you have in mind and they can hook you up.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
I'd try PL polyurethane adhesive to attach the granite. And if you're using granite you don't need spikes.
I made a stone-like slab base out of 2 x 1 1/8" mdf panels sandwiched together and it was plenty heavy and very easy to attach. Painted it with Stone Creations but I believe they also make a marble-finish product.I remember when 'broadband' meant The Go-Go's. -
Here are a few more pics...
The first pic shows 3 out of 4 of the legs with top caps on.
The second pic has the top cap removed.
The third pic is the bottom.
The fourth pic is a closeup of the inside.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Early, those are going to be absolutly beautiful when you are done! Bravo for your ingenuity & resourcefulness!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Goning shopping this weekend for some granite bottom plates. I haven't decided what to do with the top plate. Here are some options.
1. The cheapest thing to do is nothing at all. Once speakers are set on the top plate, it'll should look fine.
2. Get matching granite to use as the top plate and affix on top of the existing top plate.
3. Replace the top plate altogether with a wood.
4. Add a thin layer of wood to the top plate to cover the screws.
Which option would look the best?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Clear silicone. This is what they use to glue Granite counter tops to cabinets.It holds real well. The liquid Nails will work but be careful because it will show if you get it anywhere and clean up is harder. They will look great.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880 -
I vote a smaller piece of granite on the top. Would look real nice!
Cool project.Terps Swimming!
HT Setup
TV: Vizio VX32L
Reciever: Pioneer VSX-D914
HD-DVD Player: Toshiba HD-A2
Fronts: Polk R50s
Surounds: Polk R30s
Center: Polk R20's
Subwoofer: SVS 20-39PCi
2CH Setup
Integrated: Onix SP3 Tube
CD Player: Sony CDP-CX355
Speakers: Onix Strata Mini in PR Finish
Signal Cable: Classic Speaker, Analog 1 IC
Headphones
Grado SR 60, Bang & Olufsen A8, Shure e3
Other Stuff in Use
Onix xls, Dual Onix x-subs, Onix Ref .5, Dahlquist M903, Teac A-1D, Marantz 1060 -
Glue is used to adhere Granite fireplace facings to a wall. Try and remove it and the wallboard comes with it.Early B. wrote:Glue? Really?
One thing to be aware of if your concerned what the finished product will look like. The adhesive used can stain the Granite, so use a light color adhesive with light colored granite or dark colored adhesive with dark colored granite.
Nice job Early.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
SCompRacer wrote:The adhesive used can stain the Granite, so use a light color adhesive with light colored granite or dark colored adhesive with dark colored granite.
Nice job Early.
This is why you use clear silicone.
I think a nice light color granite with the dark wood fluted legs will look very nice. Maybe a cream type of color. Or you could use marble.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
Harmony 880 -
MSALLA wrote:This is why you use clear silicone.
There were other adhesives mentioned that he could choose to use, so I wanted to make him aware of that. Is that OK?Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Sorry, I didn't mean to offend. I put granite countertops in my kitchen and was told to use clear silicone because of the staining. I just thought granite was kind of expensive to risk staining a piece when the silicone works great with no risk. But again, I in no way ment to offend anyone.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
Harmony 880 -
No harm done. I didn't mean for my response to sound so challenging.
Considering the application, I wonder if it would be best to use something that sets up really firm, like polyurethane or Sid's Liquid Nails.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
