Power cord question
cindy100
cindy100 Posts: 256
edited October 2006 in Electronics
Hi! Not sure if I have posted this in the correct spot so... I ordered a power cord from Signal Cable which I received today. On the receipt it recommends a minimum 50 hour break in period. Right now my stereo is all taken apart; is it alright to go ahead and put the new cord on and play a CD in order to get this started? I’d like to get this done so that when everything is put back in place it will hopefully be done. Thanks so much for your help.
Cindy
Post edited by cindy100 on
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited October 2006
    That sounds like a splendid idea... go ahead and do just that. Out of curiosity, did you get the MagicPower power cord or the digital reference?
  • cindy100
    cindy100 Posts: 256
    edited October 2006
    I told him what I had and to just send whatever he recommended. The receipt says it is a Video Power Reference. I trust he knew what he was doing. I recently bought a Power Conditioner and will need a longer cord on my NAD so it will reach to the box. Wasn't even thinking at the time to order both of them.
    Cindy
  • TroyD
    TroyD Posts: 13,124
    edited October 2006
    Frank makes solid products, he wouldn't steer you wrong. Rock on.
    BDT
  • amulford
    amulford Posts: 5,020
    edited October 2006
    Cindy
    That's OK. Frank will hook you up.
  • janmike
    janmike Posts: 6,146
    edited October 2006
    I have purchased many products (power cords, speaker cables, IC's) from Frank and have always been satisfied. To reiterate what the other people indicated, Frank will do you right. Enjoy.
    Michael ;)
    NORTH of 60°
  • Ricardo
    Ricardo Posts: 10,634
    edited October 2006
    ...power cords need to break in....hmmmmmm....so, is this true also for the batteries of my discman....or by the time they brake in they are already dead????? :D:D:D
    SOPA
  • Early B.
    Early B. Posts: 7,900
    edited October 2006
    Don't worry about break-in. Just use it when your stereo is back together again..
    "God grooves with tubes."
  • steveinaz
    steveinaz Posts: 19,546
    edited October 2006
    AMEN.
