Power cord question
cindy100
Hi! Not sure if I have posted this in the correct spot so... I ordered a power cord from Signal Cable which I received today. On the receipt it recommends a minimum 50 hour break in period. Right now my stereo is all taken apart; is it alright to go ahead and put the new cord on and play a CD in order to get this started? Id like to get this done so that when everything is put back in place it will hopefully be done. Thanks so much for your help.
Cindy
Cindy
Post edited by cindy100 on
That sounds like a splendid idea... go ahead and do just that. Out of curiosity, did you get the MagicPower power cord or the digital reference?I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore
I told him what I had and to just send whatever he recommended. The receipt says it is a Video Power Reference. I trust he knew what he was doing. I recently bought a Power Conditioner and will need a longer cord on my NAD so it will reach to the box. Wasn't even thinking at the time to order both of them.
Cindy -
Frank makes solid products, he wouldn't steer you wrong. Rock on.
cindy100 wrote:I told him what I had and to just send whatever he recommended. The receipt says it is a Video Power Reference. I trust he knew what he was doing. I recently bought a Power Conditioner and will need a longer cord on my NAD so it will reach to the box. Wasn't even thinking at the time to order both of them.
Cindy
That's OK. Frank will hook you up. -
I have purchased many products (power cords, speaker cables, IC's) from Frank and have always been satisfied. To reiterate what the other people indicated, Frank will do you right. Enjoy.Michael
NORTH of 60° -
...power cords need to break in....hmmmmmm....so, is this true also for the batteries of my discman....or by the time they brake in they are already dead?????_________________________________________________
Don't worry about break-in. Just use it when your stereo is back together again..HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Early B. wrote:Don't worry about break-in. Just use it when your stereo is back together again..Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
