adding pwr amp to RT2000p
moorefieldmoorefield Posts: 23
purchasing a NAD 225x2 amp Friday and will connect it to my RT2000P. Now, is there anything i should know before connecting since the RTs have built in amps? thanks...
Polk RT2000p
Polk CS400
Polk RT15i
Denon AVR-2801
NAD 218 THX 2 channel amp
Denon DVD-1000
Audioquest Ruby IC
14 gauge spkr wire
Post edited by moorefield on
  • capitan100capitan100 Posts: 172
    edited November 2002
    I guess the only thing is to make sure it is hooked up to the high level inputs-with the gold connector in between....The high level input for the sub will convert it into a useable signal and the 225 watts will go to the midrange and tweet....
    sounds like it will rock
    Sony DA7ES 7.1 A/V Receiver
    Sony DVP-NC80V - SACD/DVD player
    CS400 - Center channel
    RT2000i - Fronts
    RT1000i - Surrounds
    a/d/s MS3/u - subwoofer
    Hitachi 62 inch HD TV
    2 Channel Room
    Niles HDL-4 Speaker Selector
    Niles HDL-6 Speaker Selector
    Sony V555ES receiver
    Sony DVP-S7700
    Polk SDA-2B
    Polk Monitor 5
    Thiel 03a
    B&W 2001 ZMF
    Signet SL-250 B/U
    a/d/s L400e
    Wharfedale Valdus 100SE
    Polk PSW 350 - subwoofer
    Pioneer Elite Big Screen
  • moorefieldmoorefield Posts: 23
    currently have the RTs connected to a Denon AVR 90wpc, but looking for more in the upper freq...hopefully, this will add something. If not, will upgrade speakers, but will always have the rock-solid amp. thanks...
    Polk RT2000p
    Polk CS400
    Polk RT15i
    Denon AVR-2801
    Denon DVD-1000
    Audioquest Ruby IC
    14 gauge spkr wire
Howdy, Stranger!
