adding pwr amp to RT2000p
moorefield
purchasing a NAD 225x2 amp Friday and will connect it to my RT2000P. Now, is there anything i should know before connecting since the RTs have built in amps? thanks...
Post edited by moorefield on
I guess the only thing is to make sure it is hooked up to the high level inputs-with the gold connector in between....The high level input for the sub will convert it into a useable signal and the 225 watts will go to the midrange and tweet....
sounds like it will rockHome Theater
Sony DA7ES 7.1 A/V Receiver
Sony DVP-NC80V - SACD/DVD player
CS400 - Center channel
RT2000i - Fronts
RT1000i - Surrounds
a/d/s MS3/u - subwoofer
Hitachi 62 inch HD TV
2 Channel Room
Niles HDL-4 Speaker Selector
Niles HDL-6 Speaker Selector
Sony V555ES receiver
Sony DVP-S7700
Polk SDA-2B
Polk Monitor 5
Thiel 03a
B&W 2001 ZMF
Signet SL-250 B/U
a/d/s L400e
Wharfedale Valdus 100SE
Polk PSW 350 - subwoofer
Pioneer Elite Big Screen -
currently have the RTs connected to a Denon AVR 90wpc, but looking for more in the upper freq...hopefully, this will add something. If not, will upgrade speakers, but will always have the rock-solid amp. thanks...
