db212s ..... need help
Cview850
Ok I had the db 212s for about 4 months now and i luv them ... loudest things i heard yet but im looking to get another 2 .. but i dnt want the box because im gettin my trunk customized for 4 ... and im just wonderin .. do polk sell these subs separate ??? like are they the db 124s ??? or somethin like that ??? cause im takin my 212s out the box wen i get the next 2 ... and i need to know this asap ... cause i see some im lookin to buy and .. if i can buy them separate it will save me a shitload and i wont have 2 pay a lot for shippin for the 80 lbs box. Thanks
AudioBahn HU : A1150N
Polk Audio : Db 690
Polk Audio : Db 570
Polk Audio : Db 212s ( 2 12s )
Sony Amp : XM-D9001GTR
Profile Amp : Ha1040
Polk Audio : Db 690
Polk Audio : Db 570
Post edited by Cview850 on
http://www.polkaudio.com/caraudio/products/db212/
Says right at the top:
db212-2
Two db124 12-inch subwoofers in a perfectly optimized enclosure.
Put Your Car Audio System On Steroids
So, i guess that's a YES, to your question
1999 Honda Civic LX - 105 gerbils at the flywheel!
Sony CDX-GT100 Head Unit
Rockford something or other 6.5" in the front. I'm taking donations for MMC6500's!
Polk Momo MMC690 6x9's in rear
Polk Momo c300.2 amp via 4ga. and a 1.5 Farad stiffy :eek:
Polk db804 8" Subs x 2, in sealed box. -
lol thanks for the info ... whats the difference between the db 124 DVC and the db 124 ??? if there is even a difference ... because im looking to buy 2 more ...AudioBahn HU : A1150N
Polk Audio : Db 690
Polk Audio : Db 570
Profile Amp : Ha1040 -
According to that same page:
"Single Voice Coil 4 Ohm drivers wired in parallel for a net 2-Ohm load, optimum for today's Class D subwoofer amplifiers."
The DVC version stands for Dual Voice Coil. Instead of having one voice coil (electro-magnet), the DVC's have two. The benefit - you can wire them for lower ohm loads, which can give you more power (if your amp can take it). Polk took the two single voice coil db124's and wired them in parallel, producing a 2 ohm load for your amp. Each db124 is a 4 ohm load by itself.
If you're going to run 4 subs, you should be able to stick with the single voice coil versions of the db124's for your future purchase. If you wire all 4 in parallel, you'll get 1 ohm into some bad-**** amp that's stable at that load. Alternately, you could run a c500.1 to a pair of them wired in parallel (just like your db212 box) at 2 ohms. You could buy two c500.1's to run 4 subs. Given each db124 handles 360W, and the c500.1 delivers over 500W at 2 ohms, that should be a decent match-up.
Sounds like you're going for quite a bit of SPL, to be running 4 12". What car is this going into?1999 Honda Civic LX - 105 gerbils at the flywheel!
Ight I get what you sayin. but yea how much do them polk audio amps run ??? i think they run a lot though. but ummm right now i got a sony xplod amp :X hah but i was really suprised when it was hooked up . never ever gave me a problem and hits harder than any system round my way. So im really thinking of getting a another one. and this is going into a 1995 grand marquis ... Looottssssss of trunk room lol. but this monday im gettin my db 6x9s and 5x7s putting in. But what is SPL ?? lol ... but the amp i got is a XM-D9001GTR any good reviews on that ... i think its pretty good lol ... Thanks ..AudioBahn HU : A1150N
Polk Audio : Db 690
Polk Audio : Db 570
Yeah, the grand marquis would definitely hold a lot of bodies in the trunk
SPL is Sound Pressure Level. There are competitions as to who has the "loudest" subs. That's SPL... SQ is Sound Quality. A lot of folks into that as well. I'm more on the SQ side. I like my subs, but don't want them too terribly loud. Just going for a good mix of sounds for my music type, which is mostly rock.
Polk c500.1's are about $400, depending where you buy them. If you're happy with your Sony, stick with it. A lot of this stuff is opinion/preference. I got my Polk amp on clearance, so it was $150, instead of $400. Generally speaking, you get what you pay for. If you can afford more expensive amps, they're worth it. Polk certainly makes great stuff, but there are others as well. I have an almost all-Polk setup, and i'm quite happy with it. I've been using cardomain.com for a lot of my mail-order stuff. They have pretty good prices on Polk stuff and whatever else you may want. I got all my power/speaker/signal wiring through them at a reasonable price.1999 Honda Civic LX - 105 gerbils at the flywheel!
Yea SPL ... i will prolly get in 2 dat tho ... cause the 2 12s hit right now without another 2 and got a lot of people beat round my way . But yea i had a question .. The guy at the shop said he was guna take the speakers out the enclosure and build the box the same way to customize the trunk and itll sound the same ... Is this true cause didnt polk build the box a certain way or will it actually sound the same ?? I was Jus wonderin cause im lookin to do this and its the only way i can fit 4 subs in my trunk with dem big ol boxes ... Any help on dat would b appreciated. ThanksAudioBahn HU : A1150N
Polk Audio : Db 690
Polk Audio : Db 570
The shape of the box doesnt affect the SQ of the sub as long as the interior volume is the same.polkaudio sound quality competitor since 2005
