Common ground
Jockos
Quick question; is the Adcom GFA-5500 common ground?
Thanks,
Jockos
Thanks,
Jockos
Post edited by Jockos on
I wouldn't know...the GFA-555 is, but that don't necessarily mean anything; grab a multimeter and measure resistance between the two negative posts; that should tell you. If result is 0 ohm, then you have common ground._________________________________________________
Jockos wrote:Quick question; is the Adcom GFA-5500 common ground?
Thanks,
Jockos
I believe that it is not a common ground amplifierJC approves....he told me so. (F-1 nut) -
HT Trookie,
When you measure the amp should the power be on or off. And whats a good scale to put it on. I have a little cheapie analog meter from radio shack.
Thanks -
I don't think it make a difference, but I would do it with the power off. If an amp is a common ground then it will be around 0 ohm.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
What Steve...Joe said; Start with the higher scale if you have more than one option (common sense...); If measure is zero, it won't matter._________________________________________________
NO it is NOT common ground. It has secondary windings. Check with ADCOM to be sure but I'm pretty positive the negative terminals can be tied together to be used with SDA's that need a common ground amp.
FYI, if you run SDA's that require a common ground and the amp isn't common ground you will eventually fry the amp and possibly the speaks.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
