What goes through the SDA cable?? Ken maybe?
madmax
Can anyone explain what goes through the SDA cable on SDA's? My 1.2's have one wire for signal and another for ground. So what is actually being fed to what? I can see maybe the left side going to the right or the right side going to the left but not both at the same time. I'm confused.
madmax
madmax
Vinyl, the final frontier...
Post edited by madmax on
Chuck, you feeling ok?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Delta's Chuck, out of phase deltas...There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
If I remember well from my crossover upgrade, the pin contact just links something on the drivers...maybe the + of one side with the - of the other (EDIT:...with a bunch of components in between...), or something like that. The Tweeters have no relation with this pin. The schematics will tell you; I know they are posted somewhere here._________________________________________________
I'm thinking we have stuff firing from both sides.
here you goDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
madmax wrote:I'm thinking we have stuff firing from both sides.
madmax
Yup, but it's the delta's between the two channels. The right signal runs out of phase into the left signal and whatever signal isn't cancelled out is put out on the drivers. But that's what I got fromt the simplistic explanation at polk and operating on the 1B's so it may be a bit off but it passess the total BS test...There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin -
So with the cable disconnected the SDA drivers do operate in phase. This was throwing me as I thought they did not operate at all with no cable. Still having a little trouble getting a feel for exactly what is happening.
madmax
Edit: I also thought the lowest bass was cut off to the SDA drivers. I don't see where that is happening.Vinyl, the final frontier...
IIRC, looking at the speakers, the left speakers SDA will be playing
[L]-[Ri] and the right would be playing [R]-[Li] where the sub i indicates out of phase information.
My understanding is that the circuit is broken without the SDA cable so the SDA drivers will not operate without the cables.
Once again, this is my understanding based off of a discussion with Stu over a year ago so I could just be blowing smoke.There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin -
The circuit is not broken. If you follow the path with the cable disconnected you have gnd through a 16mh coil to the - of the drivers and + through a 1 mh coil to the plus side of the driver. The capacitor limits the high frequencies but I thought you had to have a resistor in series with it. I'm still confused.
Max, it's magic....don't worry about it, just enjoy it.
Seriously MM, this is my tried an true link for SDA tech knowledge.
http://www.polksda.com/srsreview.shtml
reading the first page may enlighten you a little bit. I know we've all read this artcile before but there's good info in it about how the SDA works. It's not from the engineers POV but it may lessen your sudden confusion.
YMMV
I think madmax is looking for a more technical explanation...
madmax wrote:So with the cable disconnected the SDA drivers do operate in phase.
Huh. I always assumed the sda drivers went dead if you unplugged the interconnect. Cool.Jolida Tube
Polk 11T, 7, 5, 5jr, 4
Standard equip not worth bragging about. -
They don't work with the cable disconnected. They appear to move, but that's because of the sealed design.Political Correctness'.........defined
President of Club Polk -
madmax wrote:The circuit is not broken. If you follow the path with the cable disconnected you have gnd through a 16mh coil to the - of the drivers and + through a 1 mh coil to the plus side of the driver. The capacitor limits the high frequencies but I thought you had to have a resistor in series with it. I'm still confused.
madmax
I agree if the cable is disconnected then the dimensional array is working in phase but at a different cross over point. From what I see in the schematic.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
jdhdiggs wrote:My understanding is that the circuit is broken without the SDA cable so the SDA drivers will not operate without the cables.
Yes that statement seems true also, because without the cable than the SDA drivers will not operate the way they where intended. But on the other hand will operate like any other speaker when disconnected.
Ok getting as clear as mud :eek:
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
heiney9 wrote:Max, it's magic....don't worry about it, just enjoy it.
I've done that for too long. Now I want to know the guts to the story.
Much like tubes it is cool to know they sound good and where to buy them but after awhile you start wondering just how the electrons move through them, why they are blue, why you have such high voltages etc.
Buy a book....with actual words instead of pop-ups.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Well, its the same thing as having three ducks and three nuns.
I seem to recall isolating the SDA drivers at some point and that they did not work without the cable.
RT1
