What goes through the SDA cable?? Ken maybe?
madmax
madmax Posts: 12,434
edited October 2006 in Vintage Speakers
Can anyone explain what goes through the SDA cable on SDA's? My 1.2's have one wire for signal and another for ground. So what is actually being fed to what? I can see maybe the left side going to the right or the right side going to the left but not both at the same time. I'm confused.
madmax
Vinyl, the final frontier...
Post edited by madmax on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited October 2006
    Chuck, you feeling ok?
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited October 2006
    Delta's Chuck, out of phase deltas...
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • Ricardo
    Ricardo Posts: 10,636
    edited October 2006
    If I remember well from my crossover upgrade, the pin contact just links something on the drivers...maybe the + of one side with the - of the other (EDIT:...with a bunch of components in between...), or something like that. The Tweeters have no relation with this pin. The schematics will tell you; I know they are posted somewhere here.
    SOPA
  • madmax
    edited October 2006
    I'm thinking we have stuff firing from both sides.
    madmax
  • hoosier21
    hoosier21 Posts: 4,418
    edited October 2006
    here you go
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • jdhdiggs
    edited October 2006
    madmax
    Yup, but it's the delta's between the two channels. The right signal runs out of phase into the left signal and whatever signal isn't cancelled out is put out on the drivers. But that's what I got fromt the simplistic explanation at polk and operating on the 1B's so it may be a bit off but it passess the total BS test...
  • madmax
    edited October 2006
    So with the cable disconnected the SDA drivers do operate in phase. This was throwing me as I thought they did not operate at all with no cable. Still having a little trouble getting a feel for exactly what is happening.
    madmax
    Edit: I also thought the lowest bass was cut off to the SDA drivers. I don't see where that is happening.
  • jdhdiggs
    edited October 2006
    IIRC, looking at the speakers, the left speakers SDA will be playing
    [L]-[Ri] and the right would be playing [R]-[Li] where the sub i indicates out of phase information.
    My understanding is that the circuit is broken without the SDA cable so the SDA drivers will not operate without the cables.
    Once again, this is my understanding based off of a discussion with Stu over a year ago so I could just be blowing smoke.
  • madmax
    edited October 2006
    The circuit is not broken. If you follow the path with the cable disconnected you have gnd through a 16mh coil to the - of the drivers and + through a 1 mh coil to the plus side of the driver. The capacitor limits the high frequencies but I thought you had to have a resistor in series with it. I'm still confused.
    madmax
    heiney9 Posts: 25,440
    edited October 2006
    Max, it's magic....don't worry about it, just enjoy it. ;):p .
    edited October 2006
    Seriously MM, this is my tried an true link for SDA tech knowledge.
    http://www.polksda.com/srsreview.shtml
    reading the first page may enlighten you a little bit. I know we've all read this artcile before but there's good info in it about how the SDA works. It's not from the engineers POV but it may lessen your sudden confusion.
    YMMV
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited October 2006
    I think madmax is looking for a more technical explanation...
  • riglehart
    riglehart Posts: 276
    edited October 2006
    Huh. I always assumed the sda drivers went dead if you unplugged the interconnect. Cool.
    Jolida Tube
    Polk 11T, 7, 5, 5jr, 4
    Standard equip not worth bragging about.
    F1nut Posts: 51,783
    edited October 2006
    They don't work with the cable disconnected. They appear to move, but that's because of the sealed design.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited October 2006
    madmax
    I agree if the cable is disconnected then the dimensional array is working in phase but at a different cross over point. From what I see in the schematic.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • disneyjoe7
    edited October 2006
    Yes that statement seems true also, because without the cable than the SDA drivers will not operate the way they where intended. But on the other hand will operate like any other speaker when disconnected.
    Ok getting as clear as mud :eek:
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • madmax
    edited October 2006
    I've done that for too long. Now I want to know the guts to the story. :D
    Much like tubes it is cool to know they sound good and where to buy them but after awhile you start wondering just how the electrons move through them, why they are blue, why you have such high voltages etc.
    madmax
  • dorokusai
    dorokusai Posts: 25,576
    edited October 2006
    Buy a book....with actual words instead of pop-ups.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited October 2006
    Well, its the same thing as having three ducks and three nuns.
    I seem to recall isolating the SDA drivers at some point and that they did not work without the cable.
    RT1
