LSI 15 diasaster
Jockos
Jockos Posts: 310
edited October 2006 in Speakers
My 21 month old son toppled my R LSI 15 speaker. One corner is crunched and between the ring tweeter and mid. drivers there is cracks. The enclosure problaby cracked internally. Does anyone know if polk would sell the enclosure?
Bummed out in paradise,
Jockos
Post edited by Jockos on
    F1nut Posts: 52,002
    edited October 2006
    I hope your son is ok!
    Call Ken about the cabinet.
  • organ
    organ Posts: 4,969
    edited October 2006
    What's with all this LSi disasters lately?
  • Jockos
    Jockos Posts: 310
    edited October 2006
    I'm sorry I forgot to mention that he's o.k. Thats the main concern, thanks. Good thing my other 5 month old isn't quite mobile yet! I'll call Ken tommorrow.
    billbillw Posts: 7,800
    edited October 2006
    Scary stuff. Glad to hear nobody was hurt.
    Just goes to show you, floorstanding doesn't mean safe. I'm actually going to have to get some kind of anchors for my RT800i and rethink my Monitor 5s on stands before our baby starts toddling. Nylon straps screwed to the back and sunk into a stud? That's what all the tall bookshelves are doing now. I hate to screw into the back, but safety is more important than preserving the speaker.
  • McLoki
    McLoki Posts: 5,231
    edited October 2006
    You could get some plastic strap (any hardware store will have it) and screw it into a stud and then use some strong 3m tape (like they use to put the side panels on the LSi's) and stick the strap to the back of the speaker. Should withstand any jolts (especially if it starts fairly taught) and can be removed later with no ill effects.
    Michael
  • cheddar
    cheddar Posts: 2,390
    edited October 2006
    May I suggest the superyard xt strategically placed around equipment and mounted firmly to the wall or furniture. I've seen it used effectively for a variety of toddler situations:
    http://www.walmart.com/catalog/product.do?dest=9999999997&product_id=1762411&sourceid=1500000000000001353000
    It doesn't look so good, but it looks a lot better than a crushed cabinet :(.
    The keyhole mounts on polk speakers also work really well for wall mounting, and I've even had success rigging my lsi/fxs to hang from heavy duty ceiling mounts using the factory keyholes.
  • Jockos
    Jockos Posts: 310
    edited October 2006
    We have a superyard XT in the living room. Great item that held him for 21 months. Of course he now climbs over it. But I still might put one in the front of the system, if only they were a little higher........talked to Ken and we have a solution. Polk Customer service is no.1 bar none!!!!
    Jockos
    And thats just the older one!
  • WilliamM2
    WilliamM2 Posts: 4,808
    edited October 2006
    How about one of those underground fences, and a collar for the kid. ou could install it under the floor in the basement.
    Only thinking of the childs safety.:D
  • Jockos
    Jockos Posts: 310
    edited October 2006
    Those have been fleeting thoughts........
  • BaggedLancer
    BaggedLancer Posts: 6,371
    edited October 2006
    barbed wire.......first time he touches it will teach him a lesson he never forgets.....
  • cheddar
    edited October 2006
    Well, I'm sure the barbed wire would help, but if the kid is determined, even anchoring the cabinet to the wall won't prevent him from prying off the grilles and 'experimenting' with the drivers...
    You might want to just get a pair of cheap r30s for a year. Drill holes and anchor them to the wall studs. After a year of banging those around, he should get bored of them and move on...;)
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited October 2006
    Tie a pit bull to them.:p
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • cmy330go
    cmy330go Posts: 2,341
    edited October 2006
    Cover each speaker with tin foil and hook up an electric fence controller. I know a guy that did that with a cat that he couldn't keep off his kitchen counter. You could throw that cat at the counter now and he would find a way in mid flight to land elsewhere.
    All joking aside, glad your kid is okay, and that you've got a fix planned.
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • Jockos
    Jockos Posts: 310
    edited October 2006
