System upgrades
Jimbo64
Jimbo64 Posts: 11
edited October 2006 in Speakers
I am starting this thread to get imput from experienced users so that it will be easier for me to make my decisions without wasting money for little or no improvement on my entertainment system. I primarily use my system for movies/surround sound.
My current system consists of:
Denon AVR-4800
All speakers are Polk.
Sub: PSW650
Center: CS1000P
Front: RT2000I
Surround: FX500i
I intend to upgrade:
Receiver to the AVR4806
Surround: LSiFX
Front: LSi25
I am not sure that it would be worthwhile to upgrade my PSW650 to the PSW1000 or not.
Unfortunately there are no businesses locally (Seattle) where I can compare. Does anyone have experience with these options or imput?:confused:
Post edited by Jimbo64 on
  • halo
    halo Posts: 5,618
    edited September 2006
    Denon AVR-4800
    Sub: PSW650
    Center: CS1000P
    Front: RT2000I
    Surround: FX500i
    Surround: LSiFX
    Front: LSi25
    Forget about Polk subs. Go for SVS, HSU, or Outlaw subwoofers instead. Welcome to the Club! :)
  • Jimbo64
    Jimbo64 Posts: 11
    Thank you Halo!
    I will researcg those subs. Did you think the surround ant upgrades were good or have no opinion?
  • halo
    halo Posts: 5,618
    What's the diff between the Denons? If you want more power & cleaner sound take the dough you were going to spend on a new Denon AVR and get some separate amplification. Outlaw is an excellent place to start. It all depends on how much you want to spend. What other Polk's do you currently own?
  • Jimbo64
    Jimbo64 Posts: 11
    Just the ones listed on my original thread. My understanding is that the LS series is better for more natural imaging (ie dvd movies) where the RT series are better for music
  • Jimbo64
    Jimbo64 Posts: 11
    The problem eith my Denon is that it's technology is about ten years so it doesn't have the codecs or able to process the various movie formats
  • Early B.
    Early B. Posts: 7,900
    Your speakers are fine. I would suggest that you focus on upgrading the receiver and buying a killer sub. Don't spend too much on money a reciever. Just make sure it has pre-outs.
    Once you make those two changes, re-evaluate your system. I think you'll be pleasantly surprised. Nevertheless, if you're eventually gonna go for the Lsi series, you'll need separate amplification.
    What is your budget and room size?
    "God grooves with tubes."
  • Jimbo64
    Jimbo64 Posts: 11
    The 'room' is about 14X13 . It's an open floor plan so the entertainment (family room) actually has three walls and one open side. my AVR4800 has ample power (125) so that even at -4dbs it is louder than most people find comfortable. After a brief researcg of the SVS, SHU, and Outlaw subs, I really like the SVS. Besides the actual power, the cabinets appear gorgeous!
  • Jimbo64
    Jimbo64 Posts: 11
    I am looking for more natural and cleaner sound, not earthshaking volumn. It really already had that quality.
  • halo
    halo Posts: 5,618
    I just picked up a refurbished Harman Kardon AVR-340 here: link Pretty inexpensive and it has all the latest decodeing / processing. It sounds fantastic too. Or you could check out the AVR-440 here: link
    SVS is a very good choice! I have a 20-39 PCi myself and I love it.
  • Jimbo64
    Jimbo64 Posts: 11
    Okay. a friend of mine just bought the Polk lsi25's. We are going to hook them up next to my rt2000i's.....I will let you know what we think.
    I will be getting the AVR4306 receiver.
    I definitly want an SVS sub. HELP! Which one! Are the single 12's enough? much better than my PSW650? If so, which one, SB12+, PB12 ULTRA, OR PB12+? I may still get the PB12+/2. It's very difficult to know when I can't hear them side by side.
  • cfrizz
    cfrizz Posts: 13,415
    Hi Jimbo, welcome to CP!
    Talk to the people at SVS they will help you pick out the best sub for your room.
    I can't wait to hear your thoughts on the 2 different pairs of speakers. However, please know that if you decide to get the updated Denon as well as an all LSI setup, you will need separate amplification to get the best out of the LSI's but also to not overstress your receiver. It is not designed to really handle 4ohm speakers.
    Now that I think about it, all you might really need to make your current speakers sound their best is a separate amp.
    Do a search here on the board about the benefits of separate amplification, it makes a world of difference!
    Here is one such discussion for you to look at. Holydoc's review is just beautiful & accurate!
    http://www.polkaudio.com/forums/showthread.php?t=33040
  • gonzalr
    gonzalr Posts: 92
    sorry. trying to post a new thread. my mistake.
  • halo
    halo Posts: 5,618
    That's what I was trying to suggest Cathy. Less money on a new receiver (get a less expensive Denon that'll do all the decoding / processing) and put the difference into separate amplification.
    Ex: Denon AVR-2370CI & Outlaw Model 7125 Instead of just the Denon AVR-4306
    Call SVS as Cathy suggested. Great people that will get you exactly what you need. You can also get a SPL meter & Avia DVD from them.
  • Jimbo64
    Jimbo64 Posts: 11
    I really appreciate the suggestions. I will contact SVS as advised. I can get a good deal on the AVR-4306 (1300$). I will let you know about the LS25i vs the RT2000i's.
    So this leads to the next bag-o-worms....the amp? Denon okay?
    I say...that boy married the niece of Denon corp.
  • Jimbo64
    Jimbo64 Posts: 11
    I contacted SVS. Iwas suprised that the tech considered my PSW650 a powerful sub. He still needs to get back to me for a reccommendation for an SVS Sub. I did move my sub next to the couch and adjusted the setting on the receiver accordingly to 5'. It made a phenominal difference! I know I will replace my fx500i's with the LSiFX rear surrounds I don't think the room is big enough to go 7.1
    Hopefully the ls25's s show up today so I can get my opinion back to you guys!.
  • sickicw
    sickicw Posts: 456
    if you want "quality" i would look into a velodyne sub or some other sealed sub.
    Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
    Amps & Power: Rockford Fosgate T8004 x 3, Cascade Audio APS-55 power supplies x 5, and 1 farad capacitor.
    Electronics: Denon 3806, Toshiba HD-A1, & Sony KDL46XBR2
    Accessories: Anti-IC interconnects, 8 Mondo Traps from Realtraps, and Salamander furniture.
  • Jimbo64
    Jimbo64 Posts: 11
    edited October 2006
    Okay,
    I hooked up the AVR-4306. Noticably crisper video and even moreso on the audio. Guess my buddy doesn't get it back! I would like the SVS Sub but I don't have the room for it. I may just settle for the PSW1000 which would still be noticably better than my PSW650.
