Just installed my RD0-194 tweeters
dagame27
dagame27 Posts: 600
edited September 2006 in Vintage Speakers
They do make a nice difference. There is a much more laid back quality to the sound now. Thank you to past threads which led me to try this out. Definitely the easiest installation possible. The general rule is, if I can do the installation than anyone can!
ChrisIntegrated Amp: Cary SI-300D Processor: Marantz SR7012 Streaming: Bluesound Node 2I 4K Bluray: Panasonic UB820Mains: Von Schweikert VR2Center: Von Schweikert LCR15 Subs: 2 SVS Sb13 Ultra (HT Only) Analysis Plus Cables
Post edited by dagame27 on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    Wait until they actually break in, it's only going to get better.
    Cheers,
    Russ
  • Mike Reeter
    Mike Reeter Posts: 4,315
    The RDO's are smooth as Silk:D
  • george daniel
    george daniel Posts: 12,096
    Congrats,,enjoy:)
  • schwarcw
    schwarcw Posts: 7,360
    Your 2A's are singing now! Congrats and happy listening!
    Carl
  • Roy Munson
    Roy Munson Posts: 886
    When I first put the silk tweeters in my SDA's I really like the difference but I thought they were a little on the dark side, well..after a little break in time they just got better and better! No longer are they a little dark and it's really a great upgrade that I think most would like.
    Enjoy!
    2 Channel:
    Amp/Parasound Halo A23
    Pre/Carver C-1
    Tuner/Carver TX-11a
    CDP/Jolida JD 100A
    Turntable/AR XB-Shure V15 III
