Just installed my RD0-194 tweeters
dagame27
They do make a nice difference. There is a much more laid back quality to the sound now. Thank you to past threads which led me to try this out. Definitely the easiest installation possible. The general rule is, if I can do the installation than anyone can!
ChrisIntegrated Amp: Cary SI-300D Processor: Marantz SR7012 Streaming: Bluesound Node 2I 4K Bluray: Panasonic UB820Mains: Von Schweikert VR2Center: Von Schweikert LCR15 Subs: 2 SVS Sb13 Ultra (HT Only) Analysis Plus Cables
Post edited by dagame27 on
Wait until they actually break in, it's only going to get better.
Cheers,
The RDO's are smooth as Silk:D
When I first put the silk tweeters in my SDA's I really like the difference but I thought they were a little on the dark side, well..after a little break in time they just got better and better! No longer are they a little dark and it's really a great upgrade that I think most would like.
Enjoy!2 Channel:
Amp/Parasound Halo A23
Pre/Carver C-1
Tuner/Carver TX-11a
CDP/Jolida JD 100A
Turntable/AR XB-Shure V15 III
