Thinking of buying Modular Home???
13»
  • Maurice
    Maurice Posts: 517
    edited September 2006
    As a real estate investor, I can tell you modular is the way to go. Faster, cheaper and better build quality. Check out the mansions at www.modular-experts.com to see what can be done. Also, DIY Network has a show called "Assembly Required" that deals only with modular construction.
    Everytime I think I'm out, THEY PULL ME BACK IN!!!!!!
    Polk 70's,40,30's
    Velo DLS 3500 Sub
    JVC 61" HD-ILA
    Sony DA4ES AVR
    Oppo 981 DVD
    Sony CDP-CX235 CD
    Signal Bi-wires
    AR ProII IC's
  • ublguy
    ublguy Posts: 51
    I live in a modular home, we picked a design we liked and modified it to our standards.
    PRO'S
    • 2x6 construction
    • Build indoors, no rain, no snow
    • Modular codes are more strict than state codes
    • Faster: 3 months from purchase to move in
    • No visual differences
    A lot of the negativity around the modular homes are coming from the contractors who work on stick built homes. They are losing a ton of money, since Modular homes are almost all finished.
    Personally, it's been a great home, and I don't see any reason why my next home won't be a modular home.
    Good luck!
    Receiver: Denon-3802
    Pre-Amp: (2) Outlaw 200-m
    Fronts: Lsi9's
    Center: CS1
    Rear: R15
    Sub: 12" Velodyne
    TV: Sony 42" LCD - KDF-E42A10
  • hearingimpared
    hearingimpared Posts: 21,136
    PRO'S
    • 2x6 construction
    Good luck!
    Thanks for you feedback ublguy. One question for you. We saw a model of a modular home that we really loved. The modular dealer told us that he can make that same home with the same modular codes except that they would put a steel frame chasis on it like a double wide in escense it is the same as the modular for almost $50,000 less money. The difference in price would be because we wouldn't have to have it crane lowered onto the foundation and the builders would not have to do the same work they do with the modular bottom. They would place the steel chasis on a solid foundation and connect the necessary utilities. What do you think about this?
    Thanks Joe
  • schwarcw
    schwarcw Posts: 7,360
    What's the spacing of the steel beams in the chassis? I'm thinking if it's too wide the plywood wood floor would tend to flex more.
    Carl
  • hearingimpared
    I don't know but I will find out and get back to you.
    Thanks,
    Joe
  • faster100
    faster100 Posts: 6,124
    on that show, home makeover.. where they build homes for troubled families.. they always use modular homes.. they cart in the walls, roof and make a foundation and slap it together, million dollar homes, 2 and 3 story.. nothing cheap or trailer about them..
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • hearingimpared
    I know that they don't use plywood on the floors. It is supposed to be some kind of high quality wood material, I guess some very dense particle board or something along those lines. I will find that out also and get back to you on it.
    Joe
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Not sure about a floor being not supported by beams spaced wide. I lived in a home outside of San Francisco, CA that had a floor of plywood on 4' beams the floor was 2 sheets of 1" plywood, yes it had a bit of flex to it.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • kmac2
    kmac2 Posts: 34
    I looked into modular home myself awhile back and suggest, as others here have, that you find present owners and talk to them about what they've learned and what they'd do differently. Something that bothered me was how the price skyrocketed when changes or material substitutions were considered, ie; drywall vs composite wallboard panels, wood windows vs vinyl, 40 yr shingles vs 20 yr, upgrading the flooring, adding a crawlspace or basement vs slab - the plans and models I looked at had the air ducts near the ceilings, very inefficient for heat delivery, the other thing to consider about having a house on a slab is the comfy give a floor over a basement provides. And then there's the lack of appreciation on a house like this. All that being said, I was very attracted to the floorplans, the space, and the archetectural styles available, especially the one's with the low slung rooflines and wide deep porches that mimic the old 20's craftsman houses I love so much.
  • ND13
    ND13 Posts: 7,601
    My inlaw's house has appreciated dramatically over the last 5 years. When it was completed, it was appraised for $285k...last month it was appraised for $425k(the values would be dramatically higher if the home wasn't in an area that's going through an economic recession from factory closings). I'd say that whether it appreciates or depreciates has the same factors involved as with any conventional home.
    I've also yet to see a "modular" that DIDN'T come standard with sheet-rock walls. The only homes I've ever seen with composite walls were manufactured houses. Now, I'm sure there are lots of different options to choose from when picking out a "modular", so just pick a company that's been doing "modulars" for some time, not some fly-by-night operation, that offers things that seem to good to be true.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • hearingimpared
    Thanks you guys for all the input and suggestions.
  • hearingimpared
    attachment.php?attachmentid=19620&stc=1&d=1159239277attachment.php?attachmentid=19619&stc=1&d=1159238758After all that, and I humbly thank you all for the feedback, my wife and I put a bid on a "stick built" house today. The reason for this is that when this house came on the market it was a bit above the top of our price range but is a very nice home, in a nice neighborhood, in a good school district that is move in ready, with pretty much everything we wanted in a home. After listing all the pros and there were a s#!+ load there really was only two cons, the price and it was not quite as big (internal sq footage wise) as we wanted. The price came down into our price range (and that was actually a typo in the original listing) so we went for it. If it is not accepted we will probably go the modular route.
    I have to add more . . .this house in on a very nice cul-de-sac, has a pool (my wife & kid like this I don't), a beautiful raised deck, a very large back yard, horse-shoe pits, beautiful landscaping, an attached one car garage, and that is just the outside. It has two large rooms on the lower level one I have pegged as video theater room, the other a 2ch audio room. The wife has given her blessing on these. All the rest is good stuff I don't care about but makes my wife happy.
  • disneyjoe7
    Glad to hear, good investment. Best of Luck :)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • schwarcw
    This is great news Joe! I hope your offer goes through.
    Is there enough room to host Polkfest 2007?:eek: :D
    Carl
    Carl
  • hearingimpared
    Carl
    Hey Carl,
    Maybe we can scare the hell out of the rest of the neighbors in the cul-de-sac and hold the shin-dig there! Check out the pictures.
  • Early B.
    Early B. Posts: 7,900
    That's great. I hope you and your family fulfill your dreams with this house.
    "God grooves with tubes."
  • Holydoc
    Holydoc Posts: 1,048
    Excellent! Congrats to you! Woo Hoo!
    Of course now I will not get to know all the stories about the modular home, but I guess I will live. hehe
    Holydoc (Home Theatre Lover)
    __________________________________________
    Panasonic -50PX600U 50" Plasma
    Onkyo -TX-NR901 Receiver
    Oppo -Oppo 980HD Universal DVD Player
    Outlaw -770 (7x200watt) Amplifier
    PolkAudio - RTi12 (Left and Right)
    PolkAudio - CSi5 (Center)
    PolkAudio - FXi3 (Back and Surround)
    SVS - PB-12/Plus (Subwoofer)
    Bluejean Cables - Interconnects
    Logitech Harmony 880 - Remote
  • hearingimpared
    Wow we are really bummed. Our realtor just called to inform us that someone out-bid us. Once again we are looking at it as though we were not supposed to get this home and something much better is going to come along. The great thing here is that we will get what we want for less money by going the modular route.
    Joe
  • Early B.
    No problem. You're a winner regardless of the outcome. Stick with modular and get more home for less money!!!
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    I'm sure all will turn out well.... just be glad that you'll be moving into something that requires minimal initial maintenance. The wife and I just moved into our first home about two weeks ago, and images of that movie The Money Pit keep scrolling through my head. I mean, what's $200 on cables when the first estimate for a bathroom makeover is $5k.:p
    I'm so tired of pulling staples from the hardwood floor (which will have to be sanded down this weekend) that I could choke the mailman -- if he wasn't so busy avoiding the POS mailbox which will have to be replaced pronto.
    Hanging drywall tonight, gents... How 'bout you?:D
    Sorry for the rant/derail. I'm just envying anyone in a position to take over a home and prop up their feet and listen to their rig without a laundry list of Time/Life fixer upper projects peering over their shoulder.
    Best of luck to you and your fam!!!
  • Early B.
    Same here. We bought a 20 year old home about 10 years ago and it's definitely a money pit. Unfortunately, the house is not appreciating at a high enough rate to offset the CASH we have to expend each year for maintenance. Even if it was, we'd still be house-rich and cash-poor.
  • jdhdiggs
    jdhdiggs Posts: 4,305
    Carl
    If you host, Brett could educate your kids! ;)
    Congrats, looks a lot like one of the houses I grew up in.
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • bobman1235
    bobman1235 Posts: 10,822
    GREAT movie! :D
    Here lies Walter Fielding. He bought a house, and it killed him.
  • zombie boy 2000
    The fit of uncontrollable laughter that Hanks goes into after the tub falls through the floor is one of my all time favorite scenes. Effin' hilarious:D
  • hearingimpared
    Sorry to hear of your plight. I've been there several times in the past. One thing, instead of pulling the staples take a heavy thick flat head screw driver, run it up under the staple(s) and lift like a crow bar. Since your sanding the floors down this weekend it won't matter if you slightly scratch the floor with the screw driver. Using this method saved me a lot of time and sore hand muscles when I had to do that particular job in past homes.
    Thanks for the encouraging words,
    Phyllisann & Joe:)
  • hearingimpared
    If you had to do it all over again would you purchase a modular home?
    Thanks,
    Joe
  • Holydoc
    Joe
    Well it sounds like I get to hear a first hand review of a modular home afterall. Sorry about the out-bid.
  • Early B.
    I dunno. There are too many variables involved for a definitive response.
    Nevertheless, I'd strongly consider it and do a lot more research. Hell, I'd do precisely what you're doing.
  • hearingimpared
    I'm not sure of your definition of composite walls. Are you talking about compressed dense particle board? If not what?
    Thanks,
    Joe
