Polk theater speakers $1500.00
ntg
ntg Posts: 36
Hey Guys,
I have a buddy that is looking to upgrade from an old Carver 2 channel stereo system to a theater system.He wants me to come up with some ideas for his speakers and is looking at Polks.I have all Polks and he loves the sound.Can you help me with some ideas starting in the $1500.oo range for a complete set.
Post edited by ntg on
  • okiepolkie
    okiepolkie Posts: 2,258
    edited September 2006
    Does the $1500 include a receiver?
    If that is just for the speakers, here is a possible setup:
    RTi8
    CSi5
    FXi5
    Tschüss
    Zach
  • ntg
    ntg Posts: 36
    No. Just speakers and sub
  • adam2434
    adam2434 Posts: 995
    RTi6 fronts
    CSi5 center
    FXi3 surrounds
    Would be around $1000 with the current sales at crutchfield.com and free shipping.
    I'd add the $430 10" sub from SVS to round out a nice $1500 set.
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
  • okiepolkie
    I guess I forgot the sub. In that case, I would go with the 6's and the SVS.
    Tschüss
    Zach
  • Sherardp
    Sherardp Posts: 8,038
    if he can stretch it just a tad bit I would bump the 6's to 8's and either add the PB12-NSD or PB10-NSD, both end just a tad bit over the 1500 bucks. If he can swing it that is, if not then the recommended setup adam2434 mentioned would be nice little setup also though.
  • TroyD
    TroyD Posts: 13,124
    What Carver setup does he have??
    BDT
  • ntg
    ntg Posts: 36
    Troyd,
    I am not sure of the exact model.He has had it forever and it all still works.Carver reciever with 4 floor standing old infintity speakers and it still sounds great with music.
    You guys are a great help and I do appreciate it.How about a reciever for the system around or under $800.00?
    Thanks again
  • adam2434
    adam2434 Posts: 995
    This HK receiver can be had for around $700 for a refurb.
    I personally like HK mated with RTi's.
    http://www.harmanaudio.com/search_browse/product_detail.asp?urlMaterialNumber=AVR%20635-Z&status=
  • ntg
    ntg Posts: 36
    Adam,
    The HK would be my first choice as I own a older AVR 55 and love it.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    If he wants to upgrade for music I would consider other options than receivers.
    RT1
  • adam2434
    adam2434 Posts: 995
    RT1
    Good point.
    When I first read the word "upgrade" in the 1st post, I was taking it to mean "expand to surround sound capabilities".
    The options folks have suggested will do that. However, there's a chance these systems would not upgrade 2 ch performance over what the guy already has.
    ntg, you might want to make your buddy aware of this if he's really more into 2 ch. He may find that he wants to keep his old 2 ch system and build a system specifically for HT. Another option would be to build a system over time (more money) that would upgrade or maintain 2 ch performance and have surround capabilities.
  • ntg
    ntg Posts: 36
    Thanks guys,
    He does not listen to music near as much now and I was assuming that a decent av reciever would still sound fairly well on music.He has recently got married and they also want the extra room that the 4 large infinity speakers are taking up.
    So I will take any suggestios that you guys have to offer.This is a great forum and I have learned quite a bit already.
    The only problem is I now am getting the upgrade bug!:eek:
