SACD or DVD-A or Universal Player for a $300 budget
SolidSqual
Hey Guys,
Should I get a SACD or a DVD-A or Universal player? My budget is about $300. Any good recommendations for my setup? IS one format better than the other?
Post edited by SolidSqual on
SACD is more widely used than DVD-A, at least from what I've seen.If you will it, dude, it is no dream.
With the exception of Sony and Philips (SACD co-creators) and Panasonic (major DVD-A promoter), almost all manufacturers produce universal players nowadays. At the $300.00 price point, you may want to check out the Denon 1920/1930, Cambridge Audio DVD-87/89, Onkyo 502 or Pioneer Elite DV-46AV.
When done properly, both DVD-A and SACD can sound amazing. -
Get a universal player that way all your bases are covered. Danny's recommendations are good choices.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
A universal player is the way to go. You really cannot go wrong with any player you select, or the choices already listed. I would lean towards the Elite, but that's just me. Good Luck!
