enough power...
schmilnik
schmilnik Posts: 44
edited September 2006 in Speakers
hey, I have a pair of the rti10s, 6s and csi5 and psw505. I am using a hk avr335 I know that it will sound better with a seperate amp and i plan to get one later on. But will this receiver do the job and not hurt my speakers?
Post edited by schmilnik on
  • danger boy
    danger boy Posts: 15,722
    for now yes. sometimes all you need is a 2 channel amp for your fronts to really make an improvement. of course a 5 channel amp would be better.. but so much of the sound comes from the left and right fronts. that may be all you need to elevate it to the next level.
    PolkFest 2012, who's going>?
  • Sherardp
    Sherardp Posts: 8,038
    no such thing as enough power
  • wallstreet
    wallstreet Posts: 1,405
    You need more power.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Let's not scare him yet, you have enough power for now. When you what more MORE can be added.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • wallstreet
    OK, I'll rephrase. If you ever decide to add more power, you will be happier.
  • cfrizz
    cfrizz Posts: 13,415
    Agree with DisneyJoe. Start saving & get a 5 channel amp & be done with it. I started with a 2 channel, then added a monoblock, & have finally gotten a 5 channel monster (not Monster, barf) to run all 5 of my speakers! I am finally content as far as power goes!
  • faster100
    faster100 Posts: 6,124
    that should do fine with those speakers and as said before.. amps only sweeten the deal later on.. sometimes simplicity is where it's at to start anyways.. :D
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • Willow
    Willow Posts: 11,232
    FWIW, I am powering my 8's with my 335 along with my csi3 and rti 4's. They go plenty loud.
    Not to highjack but since it was mentioned, if say he and I were to each get a 2ch amp, sure the front mains would have enough juice, but wouldn't the centre and dialogue kinda lack compared to say a 3 or 5ch amp?
  • faster100
    you may have more headroom on certain subject matter on the speakers with the amp, movies or music.. however calibrated.. 75 db is 75db or what ever you calibrate it to.. it should be all equal when setup correctly.. if you drive highs with receiver and lows with the amp as an example.. you may get different levels
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • John K.
    John K. Posts: 822
    Schmilnik, it depends on factors such as the size of your room, your distance from the speakers, how loud of an average level at which you listen and the dynamic range of the program material that you play. At a comfortably loud average level your speakers use about 1 watt; how much more than that is needed on brief peaks depends on the factors mentioned above. If you're not experiencing audible distortion on peaks with your 335 now, then you're fine; relax and enjoy your music. If you have enough power now, using two or three boxes instead of one doesn't bring about any special magic.
  • TroyD
    TroyD Posts: 13,124
    Quality over quantity.
