I-tunes merge??
Lowell_M
Lowell_M Posts: 1,660
edited April 2024 in Clubhouse Archives
I'm not sure where to ask this question...
I have a laptop (my work computer) and a desktop (home computer) that started out with the same I-tunes library (I copied the library off my desktop to the laptop. Since that time I have bought and ripped different songs on to each computer. I really don't have an easy way to know which computer has which songs now, but want to merge the libraries.
Does anybody know how I might re-combine these libraries and avoid any duplicates? Anything from a file utility to some kind of I-tunes plug in or something like that???? :confused::confused:
HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables
  • cmy330go
    cmy330go Posts: 2,341
    edited September 2006
    Assuming the naming was done the same way on both computers you could just copy the files from one over the top of the other and say "yes" to overwriting the duplicates. That should leave you duplicate free.
    There may be another way, but that is all I can think of with my Pre-morning coffee brain.:D
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • bobman1235
    bobman1235 Posts: 10,822
    iTunes itself may have some way of doing this. I can think of hack-y ways, but nothingr eally clean...
    For example, you could copy all of the songs from one computer to the other, add them all to iTunes, use iTunes "Show Duplicates" option to delete all the repeats, and then use that new set as your "master copy".
    Or, if you knwo what date you originally did the copy, just sort your library by add date, and everything after that original date is new and should be copied to the other PC. That's the cleanest way I can think of....
  • Lowell_M
    That is what I started doing. I was hoping there was some slick and easy way since I ended up with mountains of duplicates.
    I may just do a file copy as suggested earlier, blow away the itunes database and rebuild playlists.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
