PioneerVSX-1016TXV-K & PSW10
bigrodge
New user here guys. My new THX amp has a Sub output which I use. but on the back of my PSW10 there is no LFE IN which in the manual it shows as being there. So I've just hooked it up to one of LINE IN inputs with a high quality RCA CABLE ( ELITE )...It works but have I done it correctly and am I getting the full benefit?
Cheers Guys.
4 M50 monitors with a CS2 centre channel also...what a sound!
Cheers Guys.
Post edited by bigrodge on
It will work fine....
If you want to experience a slight decibal gain, purchase a female to male Y-splitter, and you'll be set:)
Welcome to the Forum!I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore -
Thanks mate...I appreciate that..any idea why the LFE IN is not on my sub?
bigrodge wrote:Thanks mate...I appreciate that..any idea why the LFE IN is not on my sub?
That's the $10,000 dollar question, now isn't it?
I can't really answer it for you, but rest assured you got it right.
Also, make sure your low pass filter on the back of your sub is set to the highest setting.... Wouldn't want to neglect any particular part of the frequency:pI never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore
