PioneerVSX-1016TXV-K & PSW10
bigrodge
bigrodge Posts: 16
New user here guys. My new THX amp has a Sub output which I use. but on the back of my PSW10 there is no LFE IN which in the manual it shows as being there. So I've just hooked it up to one of LINE IN inputs with a high quality RCA CABLE ( ELITE )...It works but have I done it correctly and am I getting the full benefit?
Cheers Guys.
4 M50 monitors with a CS2 centre channel also...what a sound!
Post edited by bigrodge on
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited September 2006
    It will work fine....
    If you want to experience a slight decibal gain, purchase a female to male Y-splitter, and you'll be set:)
    Welcome to the Forum!
  • bigrodge
    bigrodge Posts: 16
    Thanks mate...I appreciate that..any idea why the LFE IN is not on my sub?
  • zombie boy 2000
    That's the $10,000 dollar question, now isn't it?
    I can't really answer it for you, but rest assured you got it right.
    Also, make sure your low pass filter on the back of your sub is set to the highest setting.... Wouldn't want to neglect any particular part of the frequency:p
