A/V Wall Plates
Pablo
Pablo Posts: 723
edited September 2006 in Electronics
I'm currently in the process of rebuilding the entire wall around my fireplace and would like to put a plasma over it. I was hoping to put in jacks in the center of the wall and run them down to jacks on the shelving next to it. This way I can easily hook up things as time goes on (video games, cameras, ect).
I wanted to be able to run a jack for ever input on the TV (component, composite, HDMI, S-vid, audio and digital audio). The RCA jacks are easy, but I can't seem to find anything for HDMI or S-video. Does anyone know where I can get these? Or does anyone know what the best way of building a large plate with all those connections (instead of a bunch of standard wall plates)?
(I'm extreamly handy and willing to take on any sort of project).
Thanks.
Denon AVR-3803
RTi-70 Fronts
FXi-30 Surrounds
RTi-38 Back Surrounds
Csi-40 Center
PSW350 Sub
Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
Denon DVD-2910
Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64
Post edited by Pablo on
  • blamenewt
    blamenewt Posts: 1
    Hello friend, here are some sources you might try. I have used them all and recommend them equally for reliable and fast shipment:
    mcminone.com
    partsexpress.com
    matelectronics.com
    Good luck with your installation!
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    I did some searching myself as your HDMI got me thinking...
    Found this looks pretty cool, as I found nothing else expect HDMI plate and nothing else. This looked like you could built something just for want you needed nothing more / nothing else.
    http://www.projectorzone.com/buildyourown1.html
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • unc2701
    unc2701 Posts: 3,587
    PM me- I've got a few of the S-video jacks that'll fit in the standard wallplates.
    Backburner:Krell KAV-300i
  • Pablo
    Pablo Posts: 723
    Thanks for the help guys. I think I'm going to go with parts express. They seem to have almost everything at a pretty good price. Thanks for the offer on the s-vid jack, but I should be able to ge one there for only a few bucks.
    For the HDMI, I think I'm just going to run the cable through the wall and dangle it out the other side. (It's just to much $ for now to have an outlet on the wall [with an outlet I would need another HDMI cable])
    I checked out that custom built one, and it's a little on the pricey side. I'm trying to keep this a little on the cheaper side for now.
    thanks again.
    Denon AVR-3803
    RTi-70 Fronts
    FXi-30 Surrounds
    Csi-40 Center
    PSW350 Sub
    Denon DVD-2910
  • Grimster74
    Grimster74 Posts: 2,577
    This is probaly a last resort but if you can't find the wall plates you want, this is where I ordered mine from. They are expensive but they have everything.
    http://www2.dvigear.com/dviwallplates.html
