A/V Wall Plates
Pablo
I'm currently in the process of rebuilding the entire wall around my fireplace and would like to put a plasma over it. I was hoping to put in jacks in the center of the wall and run them down to jacks on the shelving next to it. This way I can easily hook up things as time goes on (video games, cameras, ect).
I wanted to be able to run a jack for ever input on the TV (component, composite, HDMI, S-vid, audio and digital audio). The RCA jacks are easy, but I can't seem to find anything for HDMI or S-video. Does anyone know where I can get these? Or does anyone know what the best way of building a large plate with all those connections (instead of a bunch of standard wall plates)?
(I'm extreamly handy and willing to take on any sort of project).
Thanks.
Thanks.
Denon AVR-3803
RTi-70 Fronts
FXi-30 Surrounds
RTi-38 Back Surrounds
Csi-40 Center
PSW350 Sub
Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
Denon DVD-2910
Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64
RTi-70 Fronts
FXi-30 Surrounds
Csi-40 Center
PSW350 Sub
Denon DVD-2910
Post edited by Pablo on
Hello friend, here are some sources you might try. I have used them all and recommend them equally for reliable and fast shipment:
mcminone.com
partsexpress.com
matelectronics.com
Good luck with your installation! -
I did some searching myself as your HDMI got me thinking...
Found this looks pretty cool, as I found nothing else expect HDMI plate and nothing else. This looked like you could built something just for want you needed nothing more / nothing else.
http://www.projectorzone.com/buildyourown1.html
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
PM me- I've got a few of the S-video jacks that'll fit in the standard wallplates.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
Thanks for the help guys. I think I'm going to go with parts express. They seem to have almost everything at a pretty good price. Thanks for the offer on the s-vid jack, but I should be able to ge one there for only a few bucks.
For the HDMI, I think I'm just going to run the cable through the wall and dangle it out the other side. (It's just to much $ for now to have an outlet on the wall [with an outlet I would need another HDMI cable])
I checked out that custom built one, and it's a little on the pricey side. I'm trying to keep this a little on the cheaper side for now.
thanks again.Denon AVR-3803
RTi-70 Fronts
FXi-30 Surrounds
Csi-40 Center
PSW350 Sub
Denon DVD-2910
Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64 -
This is probaly a last resort but if you can't find the wall plates you want, this is where I ordered mine from. They are expensive but they have everything.
http://www2.dvigear.com/dviwallplates.htmlMoney Talks, Mine says Goodbye Rob!!!!
