will this amp work with my MMC690s
seth2367
Hi,
i recently bought some MMC690 4ohm 100wattRMS and 300wattpeak speakers...
I have a (KAC-7201) 2 channel kenwood 150wattRMSx2 @4ohm and 800watt peak.
would it be a good idea to wire the amp to the speakers??
or would i blow them up...
I'm kind of sad because i have this amp sitting around, and i want to use it!! ahh.... if it doesn't work then i'll trade with a lower RMS amp!
but the main question.... can i hook that amp up to my speakers and not harm them?
Post edited by seth2367 on
Yes, that amp will work fine.
Make sure you dont set the gain too high and if the speakers sound like theyre being pushed too hard, they are. Back off the gain some more. But with proper settings and common sense with the volume knob, this amp will run the 690's just fine.polkaudio sound quality competitor since 2005
