upgrading my car audio system
bruce1234
I presently have a sonyxm4060gtx amp 60 watts rms @4 ohms,front speakersare mmc6500,rears are mmc690. I own a chevy express 2000 van. I want to add one 10 inch sub and replace my amp with one that will run the whole system.I play mostly rocknroll/heavy metal like tight clean bass not thundering blow my rear windows out type.Any suggestions on a very good amp and sub.I am willing to spend about 800-1000 dollars. tyvm.Bruce.
Post edited by bruce1234 on
MM2104 - http://www.polkaudio.com/caraudio/products/mm2104/
This JBL 6 channel - http://www.cardomain.com/item/JBLGTO7556IIpolkaudio sound quality competitor since 2005
how does the sony 460 amp compare to the jbl-gto 755.6 6 channel amp .should i just keep the sony to run my 4 polks and just buy another to run the 10 inch sub
The JBL is going to be built much better and make more power. Sony amps are entry level at best.
The beauty of the 6 channel is its one amp for the whole system. Much cleaner install, much easier install and cheaper to boot!polkaudio sound quality competitor since 2005
