Now I know why most cabinets are square..
Exceptional cabinet work!
So how was the burn in period been. I am looking forward to hearing your thoughts.
Dude, those are remarkable. Congrats!!George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
Those are incredible!
MikeModwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
Usher CP 6311
Phillips Pronto TS1000 Universal Remote -
Stunning!
Could you give a little more detail on the painted acrylic? how did that work, could you use something like that for shelving in a rack?
Thanks, They look awesome!Terps Swimming!
HT Setup
TV: Vizio VX32L
Reciever: Pioneer VSX-D914
HD-DVD Player: Toshiba HD-A2
Fronts: Polk R50s
Surounds: Polk R30s
Center: Polk R20's
Subwoofer: SVS 20-39PCi
2CH Setup
Integrated: Onix SP3 Tube
CD Player: Sony CDP-CX355
Speakers: Onix Strata Mini in PR Finish
Signal Cable: Classic Speaker, Analog 1 IC
Headphones
Grado SR 60, Bang & Olufsen A8, Shure e3
Other Stuff in Use
Onix xls, Dual Onix x-subs, Onix Ref .5, Dahlquist M903, Teac A-1D, Marantz 1060 -
Boonaroo wrote:So how was the burn in period been. I am looking forward to hearing your thoughts.
Extremely pleased with the sound of these speakers. The bass is thunderous and the mids and highs excellent. The cabinet design and the fact that they weigh approx. 100lbs. + each sure helps. They have surpassed my expectations and I would put them up against speakers in the $3k to $5k range any day.
Updated pic. Refinished.I remember when 'broadband' meant The Go-Go's. -
dipiazza wrote:Stunning!
I have used reverse painted acrylic on several projects now. I thought of it myself although I'm sure others have used it before.
I paint one side of a clear acrylic panel (avail. at Lowes/Menards etc..) with Paint for plastic spray paint to create a perfect black lacquer look. I have used other types of paints including brush-on craft paints with success but recommend the Rustoleum product.
I secure the panel with PL polyurethane consruction adhesive which I also use for just about everything else. It won't melt the paint and is exceptionally strong. Just clamp it up overnight. It also expands when curing so keep it an inch or so from the edges. This expansion btw also makes it an excellent adhesive for making/sealing cabinets.
Pics of techinique;
-Customized Athenas showing gloss black on smaller one and reverse painted (used craft paints) acrylic faux wood grain on other.
-DIY 8" 2-way
-Redone Boston Acoustics A60
Hope that helps.I remember when 'broadband' meant The Go-Go's. -
Those all look awesome. So im guessing the acrylic is pretty thin? Was it expensive? (if you dont mind)Terps Swimming!
HT Setup
TV: Vizio VX32L
Fronts: Polk R50s
Surounds: Polk R30s
Center: Polk R20's
2CH Setup
Headphones
Other Stuff in Use
dipiazza wrote:Those all look awesome. So im guessing the acrylic is pretty thin? Was it expensive? (if you dont mind)
Acrylic is avail in several thicknesses, thicker= more$ of course. I used .080" and a panel of 28" x 36" or so was about $11.
Thinner is easier to work with but if it gets too thin it may show some warping. Thicker will look best on projects where the panel is kept flat and the edges are hidden well or integrated into the design.I remember when 'broadband' meant The Go-Go's. -
Sounds good, did you buy it at a Home Depot type store?Terps Swimming!
HT Setup
TV: Vizio VX32L
Fronts: Polk R50s
Surounds: Polk R30s
Center: Polk R20's
2CH Setup
Headphones
Other Stuff in Use
dipiazza wrote:Sounds good, did you buy it at a Home Depot type store?
Yes, Ihave a Lowes near me but also bought at Menards at times. I imagine HD has it too but ours is a mess usually.I remember when 'broadband' meant The Go-Go's. -
WOW great job!
Look fantastic.
Enjoy
ChrisReceiver: Onkyo TX-SR502-S
DVD Player: Pioneer DV-578A-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Subwoofer: 10'' Dayton 100 Watt -
beautiful................congrats.............nice.........;)
YOU should put your signature on IT.............may be start your own business.........I could be your assistant or partner.........I am a handyman with skillssssGodspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon -
These look pretty damn close. Yours look pretty damn good though.
http://cls.audiogon.com/cgi-bin/cls.pl?spkrfull&1161698694Samsung UN46C7000
Cambridge Audio 640R
Sony BDP-S570
Magnepan MMG's
Totem Dreamcatcher Center
Eleganza Bella 1200 High Performance Subwoofer
Polk R15 Surrounds
Audioquest Cables
Panamax 5510-PRO AC Regenerator
Monster Cable HTS 2500 MKII power cleaner
Nordost Blue Heaven Interconnects
