Hole In Speaker
JoeA4
JoeA4 Posts: 3
edited August 2006 in Troubleshooting
While removing a momo woofer from it's enclosure, the screw driver slipped. I poked a tiny hole in the flex material around the edge of the cone. It is very tiny and around the outer edge of the speaker where it does not flex as much. Is there any type of adhesive I can repair it with that will stay flexible? the hole is only the size of the very tip of a pen. I just want something that will keep it from tearing when the woofer is in use.
Any suggestions are welcome
Post edited by JoeA4 on
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2006
    Silicon.
