Custom Vintage Marantz Case
dipiazza
dipiazza Posts: 363
edited August 2006 in DIY, Mods & Tweaks
So I recently got this Vintage Marantz 1060 integrated amp, and also the Onix x-ls speakers and sub. I have seen that Marantz makes wooden cases for their older models. I built one myself to match my onix speakers. Check it out!
-Jake
Terps Swimming!
HT Setup
TV: Vizio VX32L
Reciever: Pioneer VSX-D914
HD-DVD Player: Toshiba HD-A2
Fronts: Polk R50s
Surounds: Polk R30s
Center: Polk R20's
Subwoofer: SVS 20-39PCi
2CH Setup
Integrated: Onix SP3 Tube
CD Player: Sony CDP-CX355
Speakers: Onix Strata Mini in PR Finish
Signal Cable: Classic Speaker, Analog 1 IC
Headphones
Grado SR 60, Bang & Olufsen A8, Shure e3
Other Stuff in Use
Onix xls, Dual Onix x-subs, Onix Ref .5, Dahlquist M903, Teac A-1D, Marantz 1060
Post edited by dipiazza on
  • schwarcw
    schwarcw Posts: 7,357
    edited August 2006
    Excellent work! I have a number of vintageMarantz pieces with original wooden cases. Your's is real nice since you made it to match your speakers. Are you going to put a vent grill on the rear?
    Carl
  • dipiazza
    dipiazza Posts: 363
    edited August 2006
    Thanks guys!
    The ply was kinda tricky. At first i was planning to use some kind of maple veneer to cover up the edges, but after i finished gluing and sanding i kind of liked the way the bands looked.
    I just sanded a bunch with finer grades. Then 3 coats of polyurethane was all it took with sanding in between. The hardest part was glueing the 45degree angles to make the box.
    Terps Swimming!
    HT Setup
    TV: Vizio VX32L
    Fronts: Polk R50s
    Surounds: Polk R30s
    Center: Polk R20's
    2CH Setup
    Headphones
    Other Stuff in Use
  • dipiazza
    dipiazza Posts: 363
    edited August 2006
    I was thinking about that... not sure what i would use or how i could attatch it and make it look good tho...
    Terps Swimming!
    HT Setup
    TV: Vizio VX32L
    Fronts: Polk R50s
    Surounds: Polk R30s
    Center: Polk R20's
    2CH Setup
    Headphones
    Other Stuff in Use
  • joeparaski
    joeparaski Posts: 1,865
    edited August 2006
    Looks like it came from the factory like that....good job!
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
