rti 10s
Hey,I just bought the rti10s and i am going to use my harman kardon avr335 to power them. Is this reciever going to work well with my 10s or should I buy and amp? What should I do? Thanks for any input!
Post edited by schmilnik on
I don't see any reason why the 335/340 couldn't power a pair of rti10's in 2channel mode. It would probably push them at +/-40 amperes of current with around 100 watts x2, despite H/K's conservative rating.
http://www.hometheatermag.com/completesystems/806system/index4.html
On the flipside, a separate amp would probably make for an improvement, but if you like the sound of the 10's and H/K then I wouldn't worry about it. -
I have the 10's and the same receiver...it will power them fine..but a seperate amp makes a big difference.Setup:
2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI -
aaharvel wrote:I don't see any reason why the 335/340 couldn't power a pair of rti10's in 2channel mode. It would probably push them at +/-40 amperes of current with around 100 watts x2, despite H/K's conservative rating.
Not 40 amperes... they're said to have been tested and they run about low 20s. Which is ridiculously good for a receiver.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
what if i use the reciever for my whole 5.1 surround sound will it still work out? I have the rti 10s for fronts csi5 for center, rti 6s for rears, and psw505 sub. -
The h/k will power the rest fine...and will give you an extra 20 watts if you want to run the 10's in stereo.Setup:
KrazyMofo24 wrote:The h/k will power the rest fine...and will give you an extra 20 watts if you want to run the 10's in stereo.
ok great. thanks! -
Start looking for an amp...after putting a modest 2 channel amp on my R50s which are kittens compared to the RTi10s, the difference was significant. I briefly hooked the speaks back to the receiver and I couldn't listen anymore. The 10s will suck up everything the HK can give and ask for more.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
KrazyMofo24 wrote:I have the 10's and the same receiver...it will power them fine..but a seperate amp makes a big difference.
I don't know if I'd say power them fine...it will power them. I say that cause I find they do an ok job of powering my 8's. There is an amp in my future.
In stereo they are fine. -
hey what do you guys think a good price is for the rti10s I want to see if I did well
get a seperate amp.....you will really notice a difference...the RTi series is very power hungry...my 12's did not wake up until i put the right juice in them...trust me when i say, a seperate amp will wake them upYamaha RX-V2600
Adcom GFA555 x 2
Yamaha CD685 cd changer
Yamaha Dvd c950 dvd changer
Polk RTi12 mains
Polk CSi3 center
Polk psw303
Polk RTi6 (surround and surround back)
Acoustic Research 12in 200 watt sub(8 years old and still hits hard:D)
WindyWillys cooling fan (works great)
Mitsubishi 52in big screen
blue jeans cables
AR interconnects -
Get yourself an amp i am working on getting one for my 8's.Samsung UN46C7000
Cambridge Audio 640R
Sony BDP-S570
Magnepan MMG's
Totem Dreamcatcher Center
Eleganza Bella 1200 High Performance Subwoofer
Polk R15 Surrounds
Audioquest Cables
Panamax 5510-PRO AC Regenerator
Monster Cable HTS 2500 MKII power cleaner
Nordost Blue Heaven Interconnects -
I definantly recommend an amp...what I meant by fine was that it wouldn't be too much of a load like the Lsi's would be. Also they still will sound good without an amp...running it on a cheap Onkyo HTIB like I did for a few days now that would sound bad.
Anyways even a $200-$300(used) amp will sound much better than the h/k, and well worth it.Setup:
oopsOnkyo TX NR 5008 modified by The Upgrade Company
Oppo BDP 93 modified by The Upgrade Company
Arcam CD37
Monitor Audio Gold GS 60
Revolver Audio Music 5 towers.(surround)
Vandersteen V2W
