rti 10s
edited August 2006 in Speakers
Hey,I just bought the rti10s and i am going to use my harman kardon avr335 to power them. Is this reciever going to work well with my 10s or should I buy and amp? What should I do? Thanks for any input!
Post edited by schmilnik on
Welcome!
    edited August 2006
    I don't see any reason why the 335/340 couldn't power a pair of rti10's in 2channel mode. It would probably push them at +/-40 amperes of current with around 100 watts x2, despite H/K's conservative rating.
    http://www.hometheatermag.com/completesystems/806system/index4.html
    On the flipside, a separate amp would probably make for an improvement, but if you like the sound of the 10's and H/K then I wouldn't worry about it.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
    edited August 2006
    I have the 10's and the same receiver...it will power them fine..but a seperate amp makes a big difference.
    Setup:
    2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
    PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI
    edited August 2006
    Not 40 amperes... they're said to have been tested and they run about low 20s. Which is ridiculously good for a receiver.
    edited August 2006
    what if i use the reciever for my whole 5.1 surround sound will it still work out? I have the rti 10s for fronts csi5 for center, rti 6s for rears, and psw505 sub.
    edited August 2006
    The h/k will power the rest fine...and will give you an extra 20 watts if you want to run the 10's in stereo.
    Setup:
    edited August 2006
    ok great. thanks!
    edited August 2006
    Start looking for an amp...after putting a modest 2 channel amp on my R50s which are kittens compared to the RTi10s, the difference was significant. I briefly hooked the speaks back to the receiver and I couldn't listen anymore. The 10s will suck up everything the HK can give and ask for more.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
    edited August 2006
    I don't know if I'd say power them fine...it will power them. I say that cause I find they do an ok job of powering my 8's. There is an amp in my future.
    In stereo they are fine.
    edited August 2006
    hey what do you guys think a good price is for the rti10s I want to see if I did well
    edited August 2006
    get a seperate amp.....you will really notice a difference...the RTi series is very power hungry...my 12's did not wake up until i put the right juice in them...trust me when i say, a seperate amp will wake them up
    Yamaha RX-V2600
    Adcom GFA555 x 2 :D
    Yamaha CD685 cd changer
    Yamaha Dvd c950 dvd changer
    Polk RTi12 mains
    Polk CSi3 center
    Polk psw303
    Polk RTi6 (surround and surround back)
    Acoustic Research 12in 200 watt sub(8 years old and still hits hard:D)
    WindyWillys cooling fan (works great)
    Mitsubishi 52in big screen
    blue jeans cables
    AR interconnects
    edited August 2006
    Get yourself an amp i am working on getting one for my 8's.
    Samsung UN46C7000
    Cambridge Audio 640R
    Sony BDP-S570
    Magnepan MMG's
    Totem Dreamcatcher Center
    Eleganza™ Bella 1200 High Performance Subwoofer
    Polk R15 Surrounds
    Audioquest Cables
    Panamax 5510-PRO AC Regenerator
    Monster Cable HTS 2500 MKII power cleaner
    Nordost Blue Heaven Interconnects
    edited August 2006
    I definantly recommend an amp...what I meant by fine was that it wouldn't be too much of a load like the Lsi's would be. Also they still will sound good without an amp...running it on a cheap Onkyo HTIB like I did for a few days now that would sound bad.
    Anyways even a $200-$300(used) amp will sound much better than the h/k, and well worth it.
    Setup:
    edited August 2006
    oops
    Onkyo TX NR 5008 modified by The Upgrade Company
    Oppo BDP 93 modified by The Upgrade Company
    Arcam CD37
    Monitor Audio Gold GS 60
    Revolver Audio Music 5 towers.(surround)
    Vandersteen V2W
Welcome!
Welcome!
