New Polk Momos
nedellis
nedellis Posts: 5
edited August 2006 in Car Audio & Electronics
Just bought two sets of Polk Momo 6.5 speakers for my truck. I bought a set of 6.5 components for the front and a set of 6.5 coaxs for the rear. I also bought a c4004 4 channel amp to power them. I already have a JL 10' sub and amp installed that gets signal from the rear speaker feeds. My stock head unit doesn't have rca outs. What is the best way to wire this set up.
PS I am not looking for the easiest way but the best way with my stock 6 disc in dash head:)
Thank in advance for any info
Ned
Post edited by nedellis on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited August 2006
    The best way to hook up a stock HU is to use one of Dave Navone's adaptors.http://www.davidnavone.com/adaptor_products.htm
  • nedellis
    nedellis Posts: 5
    edited August 2006
    I was told that the c4004 allows one to hook up speaker level inputs to the amp. You just need to splice your speakers to a set of rca cables and set the input on the amp to hi. Or am I missing something?
  • exalted512
    exalted512 Posts: 10,734
    edited August 2006
    dont use speaker level inputs, use one of the navone products
    -Cody
  • MacLeod
    MacLeod Posts: 14,358
    edited August 2006
    That is the way the Polk amp will accept speaker level inputs, but Cody is right that high level inputs are not the best way to go.
    Actually the best way would be to use a processor like JL's Clean Sweep or something from Audiocontrol that will clean up and boost the signal before it gets to the amp.
    And dont buy anything from Navone. He's a ****.
  • nedellis
    nedellis Posts: 5
    edited August 2006
    Would a JL clean sweep have a pre out for the sub or a low pass out. Should I wire up the rest of the system as front and rear coax per Polks instructions
  • MacLeod
    edited August 2006
  • exalted512
    edited August 2006
    360.1>cleansweep
    both of those are if you never want to upgrade your factory stereo though. Otherwise, just get the navone unit.
    -Cody
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited August 2006
    exalted512 wrote:
    360.1>cleansweep
    -Cody
    Totally agree......
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
