New Polk Momos
nedellis
Just bought two sets of Polk Momo 6.5 speakers for my truck. I bought a set of 6.5 components for the front and a set of 6.5 coaxs for the rear. I also bought a c4004 4 channel amp to power them. I already have a JL 10' sub and amp installed that gets signal from the rear speaker feeds. My stock head unit doesn't have rca outs. What is the best way to wire this set up.
PS I am not looking for the easiest way but the best way with my stock 6 disc in dash head:)
Thank in advance for any info
Ned
Ned
Post edited by nedellis on
The best way to hook up a stock HU is to use one of Dave Navone's adaptors.http://www.davidnavone.com/adaptor_products.htmHT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
I was told that the c4004 allows one to hook up speaker level inputs to the amp. You just need to splice your speakers to a set of rca cables and set the input on the amp to hi. Or am I missing something?
dont use speaker level inputs, use one of the navone products
nedellis wrote:I was told that the c4004 allows one to hook up speaker level inputs to the amp. You just need to splice your speakers to a set of rca cables and set the input on the amp to hi. Or am I missing something?
That is the way the Polk amp will accept speaker level inputs, but Cody is right that high level inputs are not the best way to go.
Actually the best way would be to use a processor like JL's Clean Sweep or something from Audiocontrol that will clean up and boost the signal before it gets to the amp.
And dont buy anything from Navone. He's a ****.polkaudio sound quality competitor since 2005
Would a JL clean sweep have a pre out for the sub or a low pass out. Should I wire up the rest of the system as front and rear coax per Polks instructionsMacLeod wrote:That is the way the Polk amp will accept speaker level inputs, but Cody is right that high level inputs are not the best way to go.
And dont buy anything from Navone. He's a ****. -
The Clean Sweep has pretty much anything you want on it.
http://mobile.jlaudio.com/products_cleansweep_pages.php?page_id=94
There is also the Rockford Fosgate 360.1 - http://www.rockfordfosgate.com/products/product_details.asp?cat_id=1&series_id=49&family_id=50&item_id=106185&locale=en_US
And about a hundred different processors from Audiocontrol - http://www.mobileaudiocontrol.com/dept.asp?d_id=17612&l1=17612polkaudio sound quality competitor since 2005
360.1>cleansweep
both of those are if you never want to upgrade your factory stereo though. Otherwise, just get the navone unit.
exalted512 wrote:360.1>cleansweep
-Cody
Totally agree......Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin
